I am implementing a pseudo-lidar based navigation where the depth point clouds will be computed offboard on the GCS. I will only have about 60 degree FOV. How should I structure the depth data to send over MAVLINK?
I also see that Intel RealSense uses the MAVLINK protocol. Maybe this is the easiest path if replacing the RPi companion computer with the GCS where I can do the processing? If how should I structure the mavlink message? I assume it will be a 2D array of depths
Thanks
