I’ve currently equipped a Quadcopter running ArduCopter 4.5.4 with two ultrasonic sensors of type MB1242 in directions 0 and 315 degrees (I’m planning on using eight, but I want to test with two first).
I can see plausible readings on Mission Planner’s proximity radar (strg-f in the map screen, followed by the button “Proximity” in the new window. Also, simple object avoidance in loiter mode seems to work.
However, I’m having trouble using object avoidance in missions. To test this, I made the companion computer fly the drone back and forth on a slow speed, stood in it’s way as it approached, and luckily jumped out of the way in time, because the drone didn’t show any reaction to me. There were no evasive actions, it just continued on it’s path.
The flight logs clearly show that the sensors did see me, though.
The complete flight log can be found here.
In short, the relevant parameters are:
OA_BR_CONT_ANGLE,75
OA_BR_CONT_RATIO,1.5
OA_BR_LOOKAHEAD,5
OA_BR_TYPE,1
OA_DB_ALT_MIN,0
OA_DB_BEAM_WIDTH,5
OA_DB_DIST_MAX,0
OA_DB_EXPIRE,10
OA_DB_OUTPUT,1
OA_DB_QUEUE_SIZE,80
OA_DB_RADIUS_MIN,0.01
OA_DB_SIZE,100
OA_MARGIN_MAX,5
OA_OPTIONS,1
OA_TYPE,1
PRX1_ADDR,0
PRX1_IGN_ANG1,0
PRX1_IGN_ANG2,0
PRX1_IGN_ANG3,0
PRX1_IGN_ANG4,0
PRX1_IGN_WID1,0
PRX1_IGN_WID2,0
PRX1_IGN_WID3,0
PRX1_IGN_WID4,0
PRX1_MAX,7.65
PRX1_MIN,0.2
PRX1_ORIENT,0
PRX1_TYPE,4
PRX1_YAW_CORR,0
RNGFND_FILT,0
RNGFND1_ADDR,24
RNGFND1_FUNCTION,0
RNGFND1_GNDCLEAR,10
RNGFND1_MAX_CM,765
RNGFND1_MIN_CM,20
RNGFND1_OFFSET,0
RNGFND1_ORIENT,0
RNGFND1_PIN,-1
RNGFND1_POS_X,0
RNGFND1_POS_Y,0
RNGFND1_POS_Z,0
RNGFND1_PWRRNG,0
RNGFND1_RMETRIC,1
RNGFND1_SCALING,3
RNGFND1_STOP_PIN,-1
RNGFND1_TYPE,2
RNGFND2_ADDR,18
RNGFND2_FUNCTION,0
RNGFND2_GNDCLEAR,10
RNGFND2_MAX_CM,765
RNGFND2_MIN_CM,20
RNGFND2_OFFSET,0
RNGFND2_ORIENT,7
RNGFND2_PIN,-1
RNGFND2_POS_X,0
RNGFND2_POS_Y,0
RNGFND2_POS_Z,0
RNGFND2_PWRRNG,0
RNGFND2_RMETRIC,1
RNGFND2_SCALING,3
RNGFND2_STOP_PIN,-1
RNGFND2_TYPE,2
Does anybody know why the object avoidance won’t work?
Regards.
