NTRIP with Ardusimple
Hi All,
I have installed an Ardusimple RTK2b reciever on my rover and would like to use the local NTRIP service for RTK corrections. It seems to login ok and I get to an RTK fix however it doesn’t seem to stay with a fixed solution for very long ie only about 1 minute. Also, on the RTK inject page I get an error message saying “Configuration of fixed position in Septentrio failed.”
Any help much appreciated.
Kind Regards,
Stephen
When I tried RTK on a rover I have been mostly in RTK float; however, the place had a lot of trees around.
You may check the satellites conditions at the place and time of your test:
Trimble GNSS Planning
or try to test choosing in advance the lowest HDOP interval (best below 0.4).
Thanks @Webillo I will take those suggestions on board. The Trimble GNSS Planning page looks very useful.
Kind Regards,
Stephen
Does anyone know, where this error message comes from, and what it exactly means?
