Notch Filter Tutorial
I have no issues doing the normal set-up, but for some reason the Notch Filter process escapes me. Hoping there is a good tutorial out there which shows all the steps?
I have a Matek H743, but it is the newer version without an sd card so I need to pull the logs off the dataflash.
Thank you
Pete
Well documented Notch filter config
