I am have assembled a drone not my first but this size is smaller than my usual builds.
I have set the notch filters and autotune.
I am attaching bin file for the same if any developers could have a look and advise if any changes required in regards to notch filter and pids. If that looks good then I would proceed with magfit.
I had to skip the temp calibration step as of yet.
Details
mn5008 t motors
17 inch prop
Quad x
Lion 22ah 6s
T/O weight- 4.4kgs
Log-
Initial altitude 5m in alt mode for notch filter result test and later part I flew in loiter mode at altitude above 10m. Both test had to finish in one flight
hi
so did multiple flights and the best results in terms of drone flying was with 20hz gyro filter.
115hz the drone kept pitching forward and toppling nose down during take off and at 60hz set it was doing it reverse and at times the drone flew but in alt mode lot of thrst and altitude change.
so i finalzed with 20hz
log for the same - notch filter flight.bin - Google Drive
i was unable to enable the maghfit prams, even the software error kept coming and kept retrying so skipped the magfit flight and finished the autotune.
a flight was made in loiter mode and attitude logging was on.
@sauravhobyy we already spoke a couple of times, and I thought you understood that you should be using ArduPilot Methodic Configurator to avoid these and other beginner mistakes. Can you help me understand why you are still not using the software?
Except temp cal ( because this drone is going to fly at a same location and there will be 10-15 mins of time when the autopilot will be powered enough time to get it warmed up )
Rest all steps were followed when I reached the magfit setup file, it asked to reboot to get magfit pram enabled and then it kept giving error( shall share tom ) so had to connect to MP and there was not magh prams. So just to continue the day i went ahead wit other steps of tuning keeping in mind that I would have to restart the tuning process.
