as a newbe with this auto pilot platform, I have the following problem.
since I arm the motors (stabilize mode), the props start to spin slowly (normal) if I give some more throtle to my transmitter, the motors start spinning a litle faster but as more throtle I push the rpm’s doesn’t change at all…
I also have calibrate my radio and the esc.
**in INITIAL SETUP/OPTIONAL HARDWARE/COMPASS-MOTOR CALIBRATION if I start the procidure, the motors seems to respont well
I had the same problem.
Pls check the following parameters:
THR_MAX and MOT_TCRV_MAXPCT. For whatever reasons my paramters contained wrong values causing no more than 50% power.
THR_MAX should be set to 1000. If this does not help, set
MOT_TCRV_MAXPCT to 80.
[quote=“mtbsteve”]Hi,
MOT_TCRV_MAXPCT to 80.[/quote] solved… you have right! thanks!!!
