Is it possible to use a normal switch (on/off) instead of the usual safety switches? How do I have to wire the switch then? What do I have to change in Mission Planner?
Why you want to do that?
The safety switch is a push button not an on/off swtich.
Because I have a built-in switch in my frame and I want to use it.
Use it then. Flip it on, wait for it to activate and flip it off. Or disable the switch and forget about it. The 1st time I had to reach thru the props to press the button was the last time I used a safety switch on a multirotor. That was ~10 models ago.
The safety switch is a lousy alternative to “Emergency Stop”
And there aren’t any good places for an E-stop button on a copter either.
