BTW if you had used ArduPilot methodic configurator from the beginning, like @ODMerdin did, you would have avoided all this missconfigurations and would have a working throttle based notch filter by now.
And it would have saved you the trouble of the FFT rabbit hole that you’ve followed.
@amilcarlucas Hi amilcarlucas, I have a question for you. My aircraft is a 4+1 VTOL fixed-wing, running the Plane firmware with Q_ENABLE=1 set. I am planning to collect data using the method that relies on raw IMU logs for FFT analysis; however, I noticed that the default value for LOG_BITMASK is 65535. Do I need to change it to 180222?
Unfortunately quadplane support in AMC is still work in progress so that value might be incorrect, sorry. You need to read the docs and set the manual override checkbox for any incorrect parameter.
