I am having an issue when using Mission Planner when flying a fixed wing aircraft. Usually the telemetry log would be in the FIXED WING folder and I can replay it back no problem. However I keep finding that it has placed the log in the GENERIC folder and when I play it back no data shows in Mission Planner. During the actual flight all the data is been displayed as it should in Mission Planner.
Just some additional information - I tried connecting with MP on a different PC and that worked OK. It stored the log in the FIXED WING folder and the log played back OK. However, on a third PC it again stored the log in the GENERIC folder and it didn’t show any data when played back.
Do you happen to have some mavlink devices onboard ? Or a multi vehicle setup ?
The target folder is determined from the heartbeat messages, and some mavlink devices with GENERIC type field can affect it.
It’s not a multi-vehicle setup. I am using a Matek mlrs receiver onboard which is used for telemetry and RC signal. The thing I don’t understand is why it works ok with one laptop and not another.
