this is my second post with the same issue, I amm trying to find solution to big issue I am facing…
I am using Pixhawk 2.1 black cube with arducopter 4.5.7, superP 14Ch 2.4Ghz programmed CRSF using ch13 (RX)and 14 (TX)
using telmetry 1
wiring the cables red, TX, RX, -,-,G
G,Red, TX (ch13) top left
-,-,RX (Ch14) top middle
I installed the Yaapu 2.0 in my TX16S
also * Set SERIAL1_PROTOCOL = 23
Set [RSSI_TYPE] = 3
tried RC_option 8 and 0
it is showing No telemetry Data no GPS
I am powering the FC using 20A casle BEC
also using Opto HW 200A ESC platinum V4 ESC
That’s not right, it’s a bitmask. It’s default which is usually 32 plus the bit for “use passthru for CRSF telemetry”. Just click the Options> “Set Bitmask” button and click the option. Then you don’t need to know anything about bitmasks.
it was loud ohhhh, the wife heard my creaming from the other side of the house
now, the flight modes reading different than the mission planner, is that normal?
when I use the programmed 6 P swtich to change between the flight mode, is giving me different than the mission planner ( I am using the MAVlink also to verfy the screen on my PC)
I just tried on and off both same result,
in the mission planner the flight mode 1 mode = Stab but in the radio Altctl and so on all different than the mission planner.
Altctl? That’s a new one, don’t know what that is. maybe it’s a PX4 Mode and there is still that problem.
Edit: This is the problem. Wrong Flight Mode
But editing the file as he did should not be necessary.
Do you have the right Folder structure on the Sd card? Yaapu Installtion
I am sure I fallow the setup guide and copied the files and dropped them in the right spot, you think this is the reason the radio giving me different delight modes?
For sure. There is no Altctl flight mode in Ardupilot and it’s the same issue posted as a PR in the link… I think you will have to write the Yappu files again and DO NOT enable PX4 flight modes.
Great news!
I fixed the problem and it was just like what you said,
I formatted the SD card then I replaced the Lua files outside the original folder not inside.
And boom all is good!
Now I am going to do the same thing with my other bird (3DR Pixhawk) hopefully I will not need to buy another special cables.
I also going to connect my ESC RPM into the Aux5 in the FC and see if I will receive any RPM information
But I think I must assign Aux5 to be RPM reader !?
This is going to be little hard for me to figure it out.
Or maybe connect it to the serial 4/5 port and assign pin 4 for RPM reading to much for me now
