I seem to be having quite a curious problem that i cannot figure out if someone is able to shed some light maybe.
So i have set up my boat its running Matek H743 fc. and running Ardurover v4.7.0
My groundsteering is mapped to channel 4 and my throttle to channel 3 and they are default. I can use my throttle as it should great than 1500 is forward and less than is reverse, 1500 middle. The issue i am having is that i have no groundsteering in manual mode. If i set it to RTL, AUTO or LOIT modes or any modes that are autonomous i will see the steering move. But when in manual mode i cannot get it to move when using the controller.
In status tab i see ch3in moving through its full range but ch3 out doesn’t move. so it is seeing the input but not allowing the output. I know the steering is physically working because if i set it to roll channel or spare rcin or even rcpassthrough on servo 3 it will work as it should. just wont work in groundsteering.
I cant leave it on these channels as ill need it for autopilot to know what steering is.
I have tried playing around with a few parameters but nothing really sticks out as to block the steering completely.
Any information on why it would not be allowing any steering just in manual, am i missing a safety parameter or something.
I will be putting together a full report on the build when i start getting some time.
