No response from ultrasonic sensor in Mission Planner?
I’m trying to integrate the MaxBotix MB1242-000 ultrasonic sensor to my Pixhawk 6C via I2C communication. I have followed the guide and changed the rangefinder type as well as max distance. The connection looks as in the picture. It’s quite sloppy, but I checked the resistance with a multimeter and I got values around ~0.3 Ohm, so the cables are not damaged.
When I check rangefinder1 in the Data menu, I just get 0 for the altitude. Any idea why this might be the case?
UPDATE:
I solved it. I had to change the RNGFND1_ADDR parameter to 112 as well. I think this should be brought up in the guide.
