Safety button is solid red, multi color led blinks blue (due to no gps reception in my flat). GCS shows copter is armed. I verified wiring of ESCs (put them directly on receiver module and they work).
I made some more tests:
I attached a servo on one of the Pixhawk’s main out ports. I can arm the copter and when I move the throttle stick, the servo moves, but only a bit. When I check the status screen in mission planner, I can see ch1out to ch4out being 988 in disarmed mode. After arming with no throttle, they are at 1078. When I move the throttle stick up minimally, the values jump to around 1100-1200 and stay there regardless, which throttle value I choose. Also ch3percent is 13 all the time, but ch3in moves from 990 to 2013 on throttle stick movements. I try this in stabilize mode.
Here is my parameter set, perhaps this will help:
#NOTE: 02.05.2014 13:56:01 Frame :
ACRO_BAL_PITCH,1
ACRO_BAL_ROLL,1
ACRO_RP_P,4.5
ACRO_TRAINER,2
ACRO_YAW_P,4.5
AHRS_COMP_BETA,0.1
AHRS_GPS_DELAY,1
AHRS_GPS_GAIN,1
AHRS_GPS_MINSATS,6
AHRS_GPS_USE,1
AHRS_ORIENTATION,0
AHRS_RP_P,0.1
AHRS_TRIM_X,0.01870215
AHRS_TRIM_Y,0.003029707
AHRS_TRIM_Z,0
AHRS_WIND_MAX,0
AHRS_YAW_P,0.1
ANGLE_MAX,4500
ANGLE_RATE_MAX,18000
ARMING_CHECK,-9
BATT_AMP_OFFSET,0
BATT_AMP_PERVOLT,18.0018
BATT_CAPACITY,4000
BATT_CURR_PIN,3
BATT_MONITOR,4
BATT_VOLT_MULT,10.1
BATT_VOLT_PIN,2
BRD_PWM_COUNT,4
CAM_DURATION,1
CAM_SERVO_OFF,1100
CAM_SERVO_ON,1300
CAM_TRIGG_DIST,0
CAM_TRIGG_TYPE,0
CH7_OPT,0
CH8_OPT,0
CIRCLE_RADIUS,10
CIRCLE_RATE,20
COMPASS_AUTODEC,1
COMPASS_DEC,0
COMPASS_EXTERNAL,1
COMPASS_LEARN,0
COMPASS_MOT_X,0
COMPASS_MOT_Y,0
COMPASS_MOT_Z,0
COMPASS_MOT2_X,0
COMPASS_MOT2_Y,0
COMPASS_MOT2_Z,0
COMPASS_MOTCT,0
COMPASS_OFS_X,-61.32848
COMPASS_OFS_Y,82.54328
COMPASS_OFS_Z,90.05787
COMPASS_OFS2_X,0
COMPASS_OFS2_Y,0
COMPASS_OFS2_Z,0
COMPASS_ORIENT,0
COMPASS_USE,1
ESC,0
FENCE_ACTION,1
FENCE_ALT_MAX,100
FENCE_ENABLE,1
FENCE_MARGIN,2
FENCE_RADIUS,150
FENCE_TYPE,1
FLOW_ENABLE,0
FLTMODE1,0
FLTMODE2,5
FLTMODE3,3
FLTMODE4,0
FLTMODE5,2
FLTMODE6,6
FRAME,1
FS_BATT_ENABLE,1
FS_BATT_MAH,0
FS_BATT_VOLTAGE,14
FS_GCS_ENABLE,0
FS_GPS_ENABLE,1
FS_THR_ENABLE,1
FS_THR_VALUE,975
GND_ABS_PRESS,101369.5
GND_ALT_OFFSET,0
GND_TEMP,43.09134
GPS_HDOP_GOOD,200
GPSGLITCH_ACCEL,1000
GPSGLITCH_ENABLE,1
GPSGLITCH_RADIUS,200
HLD_LAT_I,0
HLD_LAT_IMAX,0
HLD_LAT_P,1
HLD_LON_I,0
HLD_LON_IMAX,0
HLD_LON_P,1
INAV_TC_XY,2.5
INAV_TC_Z,5
INS_ACC2OFFS_X,0.9559228
INS_ACC2OFFS_Y,0.9395384
INS_ACC2OFFS_Z,1.028423
INS_ACC2SCAL_X,1.021257
INS_ACC2SCAL_Y,0.9795281
INS_ACC2SCAL_Z,0.993031
INS_ACCOFFS_X,-0.05416595
INS_ACCOFFS_Y,-0.1869841
INS_ACCOFFS_Z,-0.2269406
INS_ACCSCAL_X,0.9929308
INS_ACCSCAL_Y,0.9971057
INS_ACCSCAL_Z,0.9886435
INS_GYR2OFFS_X,0.07338392
INS_GYR2OFFS_Y,-0.04784813
INS_GYR2OFFS_Z,-0.01215908
INS_GYROFFS_X,-0.05187701
INS_GYROFFS_Y,0.02652629
INS_GYROFFS_Z,-0.0004091613
INS_MPU6K_FILTER,0
INS_PRODUCT_ID,5
LAND_SPEED,50
LOG_BITMASK,26622
LOITER_LAT_D,0
LOITER_LAT_I,0.5
LOITER_LAT_IMAX,400
LOITER_LAT_P,1
LOITER_LON_D,0
LOITER_LON_I,0.5
LOITER_LON_IMAX,400
LOITER_LON_P,1
MAG_ENABLE,1
MNT_ANGMAX_PAN,4500
MNT_ANGMAX_ROL,4500
MNT_ANGMAX_TIL,0
MNT_ANGMIN_PAN,-4500
MNT_ANGMIN_ROL,-4500
MNT_ANGMIN_TIL,-9000
MNT_CONTROL_X,0
MNT_CONTROL_Y,0
MNT_CONTROL_Z,0
MNT_JSTICK_SPD,0
MNT_MODE,3
MNT_NEUTRAL_X,0
MNT_NEUTRAL_Y,0
MNT_NEUTRAL_Z,0
MNT_RC_IN_PAN,0
MNT_RC_IN_ROLL,0
MNT_RC_IN_TILT,6
MNT_RETRACT_X,0
MNT_RETRACT_Y,0
MNT_RETRACT_Z,0
MNT_STAB_PAN,0
MNT_STAB_ROLL,0
MNT_STAB_TILT,0
MOT_SPIN_ARMED,90
MOT_TCRV_ENABLE,1
MOT_TCRV_MAXPCT,93
MOT_TCRV_MIDPCT,52
OF_PIT_D,0.12
OF_PIT_I,0.5
OF_PIT_IMAX,100
OF_PIT_P,2.5
OF_RLL_D,0.12
OF_RLL_I,0.5
OF_RLL_IMAX,100
OF_RLL_P,2.5
PILOT_VELZ_MAX,250
RATE_PIT_D,0.0055
RATE_PIT_I,0.07999999
RATE_PIT_IMAX,500
RATE_PIT_P,0.07999999
RATE_RLL_D,0.003
RATE_RLL_I,0.08499999
RATE_RLL_IMAX,500
RATE_RLL_P,0.08499999
RATE_YAW_D,0.003
RATE_YAW_I,0.02
RATE_YAW_IMAX,800
RATE_YAW_P,0.17
RC_FEEL_RP,100
RC_SPEED,100
RC1_DZ,30
RC1_MAX,2013
RC1_MIN,987
RC1_REV,1
RC1_TRIM,1511
RC10_DZ,0
RC10_FUNCTION,0
RC10_MAX,1900
RC10_MIN,1100
RC10_REV,1
RC10_TRIM,1500
RC11_DZ,0
RC11_FUNCTION,0
RC11_MAX,1900
RC11_MIN,1100
RC11_REV,1
RC11_TRIM,1500
RC12_DZ,0
RC12_FUNCTION,0
RC12_MAX,1900
RC12_MIN,1100
RC12_REV,1
RC12_TRIM,1500
RC2_DZ,30
RC2_MAX,2012
RC2_MIN,1001
RC2_REV,1
RC2_TRIM,1499
RC3_DZ,30
RC3_MAX,2014
RC3_MIN,988
RC3_REV,1
RC3_TRIM,989
RC4_DZ,40
RC4_MAX,2014
RC4_MIN,989
RC4_REV,1
RC4_TRIM,1502
RC5_DZ,0
RC5_FUNCTION,0
RC5_MAX,2014
RC5_MIN,988
RC5_REV,1
RC5_TRIM,990
RC6_DZ,0
RC6_FUNCTION,0
RC6_MAX,2014
RC6_MIN,988
RC6_REV,1
RC6_TRIM,989
RC7_DZ,0
RC7_FUNCTION,0
RC7_MAX,1502
RC7_MIN,1499
RC7_REV,1
RC7_TRIM,1501
RC8_DZ,0
RC8_FUNCTION,0
RC8_MAX,1503
RC8_MIN,1500
RC8_REV,1
RC8_TRIM,1501
RC9_DZ,0
RC9_FUNCTION,7
RC9_MAX,1900
RC9_MIN,1100
RC9_REV,1
RC9_TRIM,1500
RCMAP_PITCH,2
RCMAP_ROLL,1
RCMAP_THROTTLE,3
RCMAP_YAW,4
RELAY_PIN,55
RELAY_PIN2,-1
RELAY_PIN3,-1
RELAY_PIN4,-1
RSSI_PIN,-1
RSSI_RANGE,5
RTL_ALT,1500
RTL_ALT_FINAL,0
RTL_LOIT_TIME,5000
SCHED_DEBUG,0
SERIAL1_BAUD,57
SERIAL2_BAUD,57
SIMPLE,0
SONAR_ENABLE,0
SONAR_GAIN,0.8
SONAR_TYPE,0
SR0_EXT_STAT,2
SR0_EXTRA1,2
SR0_EXTRA2,2
SR0_EXTRA3,2
SR0_PARAMS,10
SR0_POSITION,2
SR0_RAW_CTRL,2
SR0_RAW_SENS,2
SR0_RC_CHAN,2
SR1_EXT_STAT,2
SR1_EXTRA1,2
SR1_EXTRA2,2
SR1_EXTRA3,2
SR1_PARAMS,0
SR1_POSITION,2
SR1_RAW_CTRL,2
SR1_RAW_SENS,2
SR1_RC_CHAN,2
SR2_EXT_STAT,0
SR2_EXTRA1,0
SR2_EXTRA2,0
SR2_EXTRA3,0
SR2_PARAMS,0
SR2_POSITION,0
SR2_RAW_CTRL,0
SR2_RAW_SENS,0
SR2_RC_CHAN,0
STB_PIT_I,0
STB_PIT_IMAX,0
STB_PIT_P,4.875
STB_RLL_I,0
STB_RLL_IMAX,0
STB_RLL_P,4.875
STB_YAW_I,0
STB_YAW_IMAX,0
STB_YAW_P,4
SUPER_SIMPLE,0
SYSID_MYGCS,255
SYSID_SW_MREV,120
SYSID_SW_TYPE,10
SYSID_THISMAV,1
TELEM_DELAY,0
THR_ACCEL_D,0
THR_ACCEL_I,1.5
THR_ACCEL_IMAX,500
THR_ACCEL_P,0.75
THR_ALT_I,0
THR_ALT_IMAX,300
THR_ALT_P,1
THR_MAX,80
THR_MID,510
THR_MIN,130
THR_RATE_D,0
THR_RATE_I,0
THR_RATE_IMAX,300
THR_RATE_P,6
TRIM_THROTTLE,60
TUNE,0
TUNE_HIGH,1000
TUNE_LOW,0
WP_INDEX,0
WP_TOTAL,0
WP_YAW_BEHAVIOR,2
WPNAV_ACCEL,100
WPNAV_LOIT_SPEED,1000
WPNAV_RADIUS,200
WPNAV_SPEED,500
WPNAV_SPEED_DN,150
WPNAV_SPEED_UP,250
