No rc receiver message
hi
I flew today : heron multiplex - taranisx9d - pixracer r15 mrobotics - arduplane 4.0.3
I had 4 times " no rc receiver " on the lua script on taranis x9d
I can’t see it in the log
Can somebody guide me
Alcala
(https://drive.google.com/open?id=11fSBQRifNvShjCMfBIhglxOKf6YLuBrD)
Good day, do you have saw this behavior during the fly or when you must arm your plane?
good morning
it was during flight
ok… just check the position of the antenna of your receiver,…what kind of receiver are you using
I am using r-xsr from frsky
The issue could be linked to throttle failsafe tbc
I am also interested to understand how to find the error messages in th elog
Thanks
Good day, just be sure that both antennas are not crossed…your receiver must be far from noise sources…just send me pls your log…
The 2 antennas are at 90 degrees
I really appreciate your help
do you mind pls attach a pic of the positions of your antennas
here it is
Thanks
Your receiver it’s no near the gps module and one antenna it’s too near a cable.
you must reposition one antenna coz the cable can disturb the signal…
ive done some tests with my frsky, x4rsb… only near electronic source or crossing the antennas i notice the message no rc receiver
thanks
i moved 3 cm the antenna and I have less errors.
I am still puzzled on how to see the error “no rc receiver” in the log file
personally i don’t have saw error about this in your log
Which Lua script are you using that is producing this message?
The one from craft&theory
OK. I suppose you will have to ask C&T. I like the Yaapu script and support here for it is great.
