I know this is a common problem but I am unable to get the dataflash logs to record. Currently I am not flying but just testing the board trying to record data while it is connected to the GCS via USB. I’m running Mission Planner 1.3.62, ArduPlane V3.9.8, and using a Pixhawk 1 board.Telemetry logs are being recorded successfully. I have tried using a different SD card, reformatting the SD card, and setting the ARMING_CHECK parameter to 0 and arming the plane. I have tried downloading the logs through Mission Planner and just by plugging in the SD card to the computer. So far everything has still resulted in no logs being created. Any help is appreciated.
