Having an issue with my 3DR X8. See youtube video. There is no wind. Every so often aircraft just goes a bit crazy and loses it stability. It has been getting worse and worse. I’m going to go through and recalibrate everything. Anyone else have an idea?
youtu.be/Twu4LmL-aUg
Please add a log file
Thanks Gary. I am new to all of this. Did some research on how to download log files. The date and times on log files didn’t actually match up with my flight times.
A number of them seem similar to the one below with a fail for the compass. I have recalibrated the compass. Is there anyway I can see if it is successful or not? Do I have to go out to the field and do another flight then check log? I might clear out all logs and then see what I am dealing with with log number 1.
[quote]Log File C:/Program Files (x86)/Mission Planner/logs/OCTOROTOR/1/2014-09-03 17-13-21.log
Size (kb) 9407.580078125
No of lines 125123
Duration 0:12:09
Vehicletype ArduCopter
Firmware Version V3.1.5
Firmware Hash ee63c88b
Hardware Type
Free Mem 0
Skipped Lines 0
Test: Balance/Twist = GOOD -
Test: Brownout = GOOD -
Test: Compass = FAIL - Large compass off params (X:-17.03, Y:-56.68, Z:-203.73)
Large compass offset in MAG data:
Z: -203.00
mag_field interference within limits (15.36%)
Test: Dupe Log Data = GOOD -
Test: Empty = GOOD -
Test: Event/Failsafe = FAIL - ERR found: FLT_MODE
Test: GPS = GOOD -
Test: Parameters = GOOD -
Test: PM = GOOD -
Test: Pitch/Roll = GOOD -
Test: Thrust = GOOD -
Test: VCC = GOOD -
[/quote]
