hi all, this is a small browser-based tool I’ve been working on that converts ArduPilot .bin logs into plain-English, readable text exports. It’s still very much a beta — I’ve recently done a significant refactor — so expect rough edges.
What it does:
Loads any Copter .bin log directly in your browser (nothing to install, no data leaves your machine)
Displays flight data on an interactive timeline (Plotly)
Lets you zoom/trim to the section you care about
Exports the trimmed data as organized, human-readable text
Shows arming status, pre-arm errors, and basic tune data detection at a glance
Prop-size aware analysis
this is Copter-focused
It’s not a replacement for Mission Planner’s log review or the full MAVExplorer — just a quick way to get a readable summary
critics welcome. happy to hear what goes wrong so they can be fixed.
cheers.
Try it here: ArduPilot Log Converter
Source: GitHub - elliotsnd/Ardupilot-Log-Converter: Browser-based ArduPilot .bin log converter. Trims to armed flight, exports human-readable diagnostics, and recovers unsaved AutoTune/QuickTune PID gains. No installs, no uploads — runs 100% client-side.
txt file should output like this
ARDUPILOT FLIGHT LOG DIAGNOSTIC EXPORT
Source File: 00000015.BIN
Vehicle Config: 5-inch props (user-specified)
Trim Range: 0.00s - 862.51s (duration: 862.51s)
Export Date: 2026-02-17
Data Messages: 2933415
SESSION STATUS: VEHICLE ARMED — CRITICAL ISSUES DETECTED
Armed 3 time(s). Last armed at t=668.29s. Disarmed at t=664.39s
FLIGHT SAFETY ASSESSMENT: 3 ISSUE(S) — CRITICAL
CRITICAL: 1
HIGH: 2
[HIGH] EKF YAW RESET — heading reference changed
→ EKF yaw estimate was reset mid-flight. Heading-dependent modes temporarily disrupted.
[CRITICAL] EXTREME ATTITUDE ERROR — Roll: 45.4° Pitch: 71.2°
→ Vehicle NOT following commands. Possible motor failure, prop loss, or mechanical failure.
DO NOT FLY until all CRITICAL issues above are investigated and resolved.
Review the ERR messages, mode changes, and sensor data below for details.
TUNE DATA DETECTED — RECOVERED GAINS
GAINS WERE SAVED — SavedGains event or “Tuning: saved” message detected.
The values below were saved to the vehicle during this session.
They should already be active on your vehicle.
AUTOTUNE FINAL VALUES
AutoTune determines optimal PID gains by commanding twitches and measuring response.
ATUN fields: RP = Rate P, RD = Rate D, SP = Stabilize/Angle P
AutoTune also sets Rate I = Rate P for Roll/Pitch axes.
── Completed Axis Results (from AutoTune summary messages) ──
Yaw Axis — COMPLETED:
Rate P = 0.141
Rate I = 0.014
Rate D = 0
Angle P = 6.046
Roll Axis — COMPLETED:
Rate P = 0.049
Rate I = 0.049
Rate D = 0.0008
Angle P = 19.499
── ATUN probe data (last logged values per axis) ──
NOTE: ATUN values are mid-probe snapshots. The Completed Axis Results above
are more accurate — they come from AutoTune’s own summary after validation.
Roll Axis — Status: AngleP_Up (probe data — see Completed Results above for final values)
ATC_RAT_RLL_P = 0.0498988 (startup value: 0.0498988)
ATC_RAT_RLL_D = 0.000848554 (startup value: 0.000848554)
ATC_RAT_RLL_I = 0.0498988 (startup value: 0.0498988) (AutoTune sets I = P)
ATC_ANG_RLL_P = 27.3663 (startup value: 19.4985)
Yaw Axis — Status: AngleP_Up (probe data — see Completed Results above for final values)
ATC_RAT_YAW_P = 0.141328 (startup value: 0.141328)
ATC_RAT_YAW_D = 2.844 (startup value: 0.01)
ATC_RAT_YAW_I = 0.141328 (startup value: 0.0141328) (AutoTune sets I = P)
ATC_ANG_YAW_P = 8.48542 (startup value: 6.04586)
│ COPY-PASTE READY — Enter these values in your GCS: │
ATC_RAT_RLL_P,0.049
ATC_RAT_RLL_D,0.0008
ATC_RAT_RLL_I,0.049
ATC_ANG_RLL_P,19.499
ATC_RAT_YAW_P,0.141
ATC_RAT_YAW_D,0
ATC_RAT_YAW_I,0.014
ATC_ANG_YAW_P,6.046
Tune Events During Session:
• AutoTune_Initialised
• AutoTune_Off
• AutoTune_Restart
• AutoTune_Reached_Limit
• AutoTune_Success
• AutoTune_SavedGains
• AutoTune_Off
• AutoTune_Success
• AutoTune_Off
Tune-Related Log Messages:
• AutoTune: Started
• AutoTune: Stopped
• AutoTune: Yaw(E) complete
• AutoTune: Yaw(E) Rate: P:0.141, I:0.014, D:0.0000
• AutoTune: Yaw(E) Angle P:6.046, Max Accel:63638
• AutoTune: Success
• AutoTune: Saved gains for Yaw(E)
• AutoTune: Roll complete
• AutoTune: Roll Rate: P:0.049, I:0.049, D:0.0008
• AutoTune: Roll Angle P:19.499, Max Accel:521799
• AutoTune: Saved gains for Roll
FIRMWARE & VEHICLE INFO
ArduCopter V4.7.0-dev (2d99a5ea) (x7)
ChibiOS: 4f34e217 (x7)
[VER] BT=10 BST=65535 Maj=4 Min=7 Pat=0 FWT=0 GH=765044202 FWS=ArduCopter V4.7.0-dev (2d99a5ea) APJ=1013 BU=2 FV=3 IMI=0 ICI=0
MatekH743-bdshot 001D002F 32335116 37393639 (x7)
Param space used: 2550/5376
RC Protocol: None
RCOut: DS600:1-4 PWM:6-13 (x7)
New mission
New rally
New fence
Frame: QUAD/X (x7)
GPS 1: specified as MSP
EKF3 IMU1 origin set
EKF3 IMU0 origin set
Field Elevation Set: 111m
EKF3 IMU1 is using GPS
EKF3 IMU0 is using GPS
EKF3 IMU0 MAG0 in-flight yaw alignment complete (x2)
EKF3 IMU1 MAG0 in-flight yaw alignment complete (x2)
GCS:Mission Planner 0.0 (x6)
IMU0: fast sampling 2.0kHz/2.0kHz (x6)
IMU1: normal sampling 1.0kHz/1.0kHz (x6)
MODE CHANGES
t=14.51s Stabilize (0) Reason=RC_Command
t=85.39s Stabilize (0) Reason=RC_Command
t=92.29s Stabilize (0) Reason=RC_Command
t=100.27s PosHold (16) Reason=RC_Command
t=101.14s Loiter (5) Reason=RC_Command
t=103.39s AutoTune (15) Reason=Aux_Function
t=114.90s PosHold (16) Reason=RC_Command
t=121.43s Loiter (5) Reason=RC_Command
t=130.59s AutoTune (15) Reason=Aux_Function
t=330.09s Loiter (5) Reason=RC_Command
t=330.74s Stabilize (0) Reason=RC_Command
t=662.69s Stabilize (0) Reason=RC_Command
t=668.29s Stabilize (0) Reason=RC_Command
t=675.67s PosHold (16) Reason=RC_Command
t=676.74s Loiter (5) Reason=RC_Command
t=682.49s AutoTune (15) Reason=Aux_Function
EVENTS & ERRORS
t=15.15s [EV] Set_Home (Id=25)
t=87.29s [ARM] DISARMED (Method=AuxSwitch)
t=87.29s [EV] Disarmed (Id=11)
t=92.29s [ARM] ARMED (Method=AuxSwitch)
t=92.29s [EV] Armed (Id=10)
t=94.29s [EV] Motors_Interlock_Enabled (Id=57)
t=96.85s [EV] Auto_Armed (Id=15)
t=97.13s [EV] Not_Landed (Id=28)
t=103.39s [EV] AutoTune_Initialised (Id=30)
t=114.90s [EV] AutoTune_Off (Id=31)
t=130.59s [EV] AutoTune_Restart (Id=32)
t=183.98s [EV] AutoTune_Reached_Limit (Id=35)
t=227.05s [EV] EKF_Yaw_Reset (Id=62)
t=304.89s [EV] AutoTune_Success (Id=33)
t=327.81s [EV] Land_Complete_Maybe (Id=17)
t=328.49s [ARM] DISARMED (Method=AuxSwitch)
t=328.49s [EV] Disarmed (Id=11)
t=328.49s [EV] Land_Complete (Id=18)
t=328.49s [EV] AutoTune_SavedGains (Id=37)
t=328.49s [EV] Motors_Interlock_Disabled (Id=56)
t=330.09s [EV] AutoTune_Off (Id=31)
t=662.69s [ARM] ARMED (Method=AuxSwitch)
t=662.69s [EV] Armed (Id=10)
t=664.39s [ARM] DISARMED (Method=AuxSwitch)
t=664.39s [EV] Disarmed (Id=11)
t=668.29s [ARM] ARMED (Method=AuxSwitch)
t=668.29s [EV] Armed (Id=10)
t=670.29s [EV] Motors_Interlock_Enabled (Id=57)
t=671.33s [EV] Auto_Armed (Id=15)
t=671.64s [EV] Not_Landed (Id=28)
t=676.15s [EV] EKF_Yaw_Reset (Id=62)
t=682.49s [EV] AutoTune_Initialised (Id=30)
t=846.49s [EV] AutoTune_Success (Id=33)
ARMING MESSAGES (PreArm checks, arm failures, warnings)
t=30.09s PreArm: Need Position Estimate
t=33.59s Arm: Need Position Estimate
t=330.09s PreArm: Battery 1 below minimum arming voltage
t=333.69s Arm: Battery 1 below minimum arming voltage
t=340.39s Arm: Battery 1 below minimum arming voltage
t=361.09s PreArm: Gyros inconsistent
t=361.09s PreArm: Battery 1 below minimum arming voltage
t=391.09s PreArm: Battery 1 below minimum arming voltage
t=422.09s PreArm: Battery 1 below minimum arming voltage
t=453.09s PreArm: Battery 1 below minimum arming voltage
t=481.09s Arm: Gyros inconsistent
t=481.09s Arm: Battery 1 below minimum arming voltage
t=483.09s PreArm: Gyros inconsistent
t=483.09s PreArm: Battery 1 below minimum arming voltage
t=492.19s Arm: Battery 1 below minimum arming voltage
t=514.09s PreArm: Battery 1 below minimum arming voltage
t=540.39s Arm: Battery 1 below minimum arming voltage
t=544.09s PreArm: Battery 1 below minimum arming voltage
t=575.09s PreArm: Battery 1 below minimum arming voltage
t=606.09s PreArm: Battery 1 below minimum arming voltage
t=637.09s PreArm: Battery 1 below minimum arming voltage
t=659.99s Arm: Throttle too high
PRE-COMPUTED DIAGNOSTIC SUMMARY
NOTE: All statistics below are computed over the selected trim range.
RMS = Root Mean Square, StdDev = Standard Deviation, Cnt = sample count
PID CONTROLLER PERFORMANCE
Fields: Tar=Desired value, Act=Achieved value, Err=Error between target and achieved, P=Proportional part of PID, I=Integral part of PID, D=Derivative part of PID, FF=Controller feed-forward portion …, DFF=Controller derivative feed-forwa…, Dmod=Scaler applied to D gain to redu…, SRate=Slew rate used in slew limiter, Flags=Bitmask of PID state flags
Roll (PIDR): (238814 samples)
Tar → mean=-0.0385 stddev=0.5868
Act → mean=-0.0055 stddev=0.5357
Err → mean=-0.033 stddev=0.487 RMS=0.4881 max|Err|=7.3829
P → mean=-0.0026 stddev=0.0337
I → mean=0.0022 stddev=0.0027
D → mean=0 stddev=0.0319
FF → mean=-0.0031 stddev=0.0253
DFF → mean=0 stddev=0
Dmod → mean=1
SRate → mean=10.0294 max=77.2864 stddev=16.4053
SRate max (77.2864) > SMAX (50) → oscillation detected on this axis!
QuickTune would reduce gain by 60% (gain margin). Consider reducing P and D.
Limit saturation → 21.2% of samples had output clipped
Pitch (PIDP): (238814 samples)
Tar → mean=-0.0313 stddev=0.2919
Act → mean=-0.0014 stddev=0.1566
Err → mean=-0.0299 stddev=0.3178 RMS=0.3192 max|Err|=5.6102
P → mean=-0.006 stddev=0.0633
I → mean=-0.007 stddev=0.0114
D → mean=0 stddev=0.0093
FF → mean=-0.0016 stddev=0.0146
Dmod → mean=1
SRate → mean=3.1539 max=22.8071 stddev=2.764
SRate max (22.8071) well below SMAX (50)
Yaw (PIDY): (238814 samples)
Tar → mean=0.0012 stddev=0.4354
Act → mean=0.0038 stddev=0.4062
Err → mean=-0.0027 stddev=0.1936 RMS=0.1937 max|Err|=4.0991
P → mean=0.0007 stddev=0.0548
I → mean=-0.0049 stddev=0.0043
D → mean=0 stddev=0.0136
Dmod → mean=1
SRate → mean=1.7841 max=9.832 stddev=1.9971
SRate max (9.832) well below SMAX (50)
Accel (PIDA): (218173 samples)
Tar → mean=0.0238 stddev=0.3837
Act → mean=0.0039 stddev=0.2309
Err → mean=0.0197 stddev=0.3995 RMS=0.4 max|Err|=12.4249
P → mean=0.0004 stddev=0.008
I → mean=0.0227 stddev=0.0609
D → mean=0 stddev=0
Dmod → mean=0.9144
SRate → mean=0.4552 max=7.0629 stddev=0.5692
Limit saturation → 15.5% of samples had output clipped
RATE CONTROLLER (target vs actual rates)
Fields: RDes=Vehicle desired roll rate (deg/s), R=Achieved vehicle roll rate (deg/s), ROut=Normalized output for Roll, PDes=Vehicle desired pitch rate (deg/s), P=Vehicle pitch rate (deg/s), POut=Normalized output for Pitch, YDes=Vehicle desired yaw rate (deg/s), Y=Achieved vehicle yaw rate (deg/s), YOut=Normalized output for Yaw, ADes=Desired vehicle vertical acceler… (cm/s/s), A=Achieved vehicle vertical accele… (cm/s/s), AOut=Percentage of vertical thrust ou…
Samples: 238814
Roll:
Desired → mean=-2.2038 stddev=33.6656
Actual → mean=-0.3163 stddev=30.6927
Output → mean=-0.0035 stddev=0.0613
TrackErr → RMS=29.0528
Pitch:
Desired → mean=-1.7926 stddev=16.7243
Actual → mean=-0.0801 stddev=8.9739
Output → mean=-0.0145 stddev=0.0773
TrackErr → RMS=18.3827
Yaw:
Desired → mean=0.0703 stddev=24.9785
Actual → mean=0.2191 stddev=23.2762
Output → mean=-0.0042 stddev=0.0569
TrackErr → RMS=15.483
ATTITUDE (desired vs actual angles)
Fields: DesRoll=Vehicle desired roll (deg), Roll=Achieved vehicle roll (deg), DesPitch=Vehicle desired pitch (deg), Pitch=Achieved vehicle pitch (deg), DesYaw=Vehicle desired yaw (degheading), Yaw=Achieved vehicle yaw (degheading)
Samples: 5454
Roll:
Desired → mean=0.4184 stddev=4.7464
Actual → mean=0.9819 stddev=5.6072
AttErr → RMS=4.4054
Pitch:
Desired → mean=0.7639 stddev=1.9133
Actual → mean=1.2114 stddev=4.3743
AttErr → RMS=4.0888
Yaw:
Desired → mean=151.335 stddev=69.4081
Actual → mean=151.326 stddev=69.3714
AttErr → RMS=1.4614
VIBRATION & IMU HEALTH
Fields: VibeX=Primary accelerometer filtered v… (m/s/s), VibeY=Primary accelerometer filtered v… (m/s/s), VibeZ=Primary accelerometer filtered v… (m/s/s)
IMU: (436345 samples)
Gyro → X: stddev=0.4795 Y: stddev=0.1637 Z: stddev=0.3553
Accel → X: mean=0.064 min=-10.129 max=8.0357 Y: mean=-0.0028 min=-10.1526 max=7.034 Z: mean=-9.8548 min=-27.1898 max=-2.4336
RAW IMU RANGE VIOLATION: AccX out of ±3 range, AccY out of ±3 range, AccZ out of -15 to -5 range
VIBE message (filtered vibration levels): (10908 samples)
VibeX → mean=2.5123 max=7.8955 [
GOOD]
VibeY → mean=3.3624 max=9.865 [
GOOD]
VibeZ → mean=1.8434 max=6.7176 [
GOOD]
Clipping → Clip0=0 Clip1=0 Clip2=0 [
No clipping]
EKF ATTITUDE CONSISTENCY (“The Leans” check):
Max Roll difference between EKF instances: 2.39° [
OK]
Max Pitch difference between EKF instances: 3.34° [
MARGINAL]
MOTOR OUTPUTS (RCOU)
Fields: C1=Channel 1 output (us), C2=Channel 2 output (us), C3=Channel 3 output (us), C4=Channel 4 output (us), C5=Channel 5 output (us), C6=Channel 6 output (us), C7=Channel 7 output (us), C8=Channel 8 output (us)
Samples: 5454
Motors:
C1 → mean=1103.1 min=0 max=1682 stddev=562.6
C2 → mean=1105.6 min=0 max=1632 stddev=563.6
C3 → mean=1093.1 min=0 max=1640 stddev=557.3
C4 → mean=1109.6 min=0 max=1638 stddev=565.6
Motor Spread (max_mean - min_mean): 16.4
Average Motor Output: 1102.9
Aux/Servo channels:
C12 → mean=1500 min=1500 max=1500 stddev=0
ESC TELEMETRY
Fields: RPM=Reported motor rotation rate (rpm), RawRPM=Reported motor rotation rate wit… (rpm), Volt=Perceived input voltage for the ESC (V), Curr=Perceived current through the ESC (A), Temp=ESC temperature (degC), CTot=Current consumed total (mAh)
Motor 1: (17309 samples)
RPM → mean=13183 min=0 max=19565 stddev=2067
Volt → mean=1.94 min=0 max=2.03
Curr → mean=0 max=0A
Temp → mean=58.4°C max=64°C [
OK]
Motor 2: (17311 samples)
RPM → mean=13158 min=0 max=18759 stddev=2025
Volt → mean=1.94 min=1.87 max=2.03
Temp → mean=53.2°C max=182°C [
OK] (max appears to be telemetry spike)
Motor 3: (17310 samples)
RPM → mean=12797 min=0 max=17049 stddev=1988
Volt → mean=1.94 min=1.86 max=2.04
Temp → mean=52°C max=57°C [
OK]
Motor 4: (17309 samples)
RPM → mean=13349 min=0 max=19481 stddev=2019
Temp → mean=56.1°C max=75°C [
OK]
RPM Spread: 552 RPM (4.2%) [
Balanced]
Average RPM: 13122
ESC telemetry RPM data detected — HNTCH_MODE=3 (ESC Telemetry) is recommended
for harmonic notch filter. This provides per-motor RPM tracking for best filtering.
PILOT INPUTS (RCIN)
Fields: C1=Channel 1 input (us), C2=Channel 2 input (us), C3=Channel 3 input (us), C4=Channel 4 input (us), C5=Channel 5 input (us), C6=Channel 6 input (us), C7=Channel 7 input (us), C8=Channel 8 input (us)
Samples: 5484
Roll (C1) → mean=1483.4 min=1350 max=1736 stddev=19.7
Pitch (C2) → mean=1502.9 min=1259 max=1598 stddev=15
Throttle (C3) → mean=1406.8 min=989 max=1862 stddev=206.7
Yaw (C4) → mean=1485.1 min=1158 max=1815 stddev=18
BAROMETER / ALTITUDE
Fields: Alt=Calculated altitude (m), Press=Measured atmospheric pressure ¶, Temp=Measured atmospheric temperature (degC), CRt=Derived climb rate from primary … (m/s), GndTemp=Temperature on ground (degC)
Samples: 5454
Alt → mean=3.49 min=-4.34 max=5.98
Press → mean=99757.21
Temp → mean=56.05
GPS QUALITY
Fields: Status=GPS Fix type: 0=NoGPS,1=NoFix,2=…, NSats=Number of satellites visible (satellites), HDop=Horizontal dilution of precision, Lat=Latitude (deglatitude), Lng=Longitude (deglongitude), Alt=Altitude (m), Spd=Ground speed (m/s), GCrs=Ground course (degheading), VZ=Vertical speed (m/s)
Samples: 2729
Satellites → mean=27.1 min=21 [
GOOD]
HDop → mean=0.56 max=0.64 [
GOOD]
Speed → mean=0.45 max=2.59
Fix Type → worst=3D Fix(3) best=3D Fix(3)
Fix Breakdown → 3D Fix:2729
GPS ACCURACY (GPA)
Fields: HAcc=Horizontal position accuracy (m), VAcc=Vertical position accuracy (m), SAcc=Speed accuracy (m/s), VDop=Vertical dilution of precision, YAcc=Yaw accuracy (deg)
Samples: 2729
Horizontal Acc → mean=1.18m max=1.8m [
GOOD]
Vertical Acc → mean=1.69m max=2.52m [
GOOD]
Speed Acc → mean=0.31m/s max=0.72m/s
VDop → mean=655.35 max=655.35 [
FIX LOST (max VDop=655.4)]
BATTERY
Fields: Volt=Measured voltage (V), Curr=Measured current (A), CurrTot=Consumed Ah, current × time (mAh), EnrgTot=Consumed Wh, energy this battery… (W.h), Temp=Measured temperature (degC), Res=Estimated battery resistance (Ohm)
Samples: 5449
Voltage → mean=19.49 min=18.49 max=20.76 (~5S) [
MODERATE (3.7V/cell)]
ALTITUDE CONTROLLER (CTUN)
Fields: ThI=Throttle input, ABst=Angle boost, ThO=Throttle output, ThH=Calculated hover throttle, DAlt=Desired altitude (m), Alt=Achieved altitude (m), BAlt=Barometric altitude (m), DSAlt=Desired rangefinder altitude (m), SAlt=Achieved rangefinder altitude (m), TAlt=Terrain altitude (m), DCRt=Desired climb rate (cm/s), CRt=Climb rate (cm/s)
Samples: 5454
Desired Alt → mean=1.41 stddev=0.94
Actual Alt → mean=1.32 stddev=1.06
Alt Err RMS → 0.2429
Throttle Out → mean=0.13 stddev=0.07
Desired SAlt → mean=2.19
Actual SAlt → mean=1.41
