Signal dropout at long distances, insufficient endurance for extended operations, repeated system debugging across different scenarios… Most remote controllers on the market either come with expensive price for premium specs, or stripped of features to meet a lower price point.
Is there a remote controller that delivers robust performance, full professional functions, without breaking your budget?
Meet the Skydroid G11 remote controller, our cost-effective masterpiece that brings professional-grade performance within 3-digit pricing!
Every configuration is engineered to solve real-world operational pain points.
Compact Streamlined Linux System,Supporting Customer Secondary Development
1. This is where the Skydroid G11 truly understands industry demands: it runs an open-source Linux operating system.
As Skydroid’s first flagship remote controller equipped with a deeply customized Linux OS, the G11 features a streamlined system. Redundant background services are removed to cut memory usage, drastically lower overall power consumption, extend endurance and speed up boot times.
Most importantly, it supports secondary development. Operators can customize the system based on project requirements using the provided source code. A single remote controller adapts to dozens of operation scenarios, maximizing your return on investment.
2. 20km Dual-Frequency,Telemetry and image&video transmission, Stable Transmission in Complex Environments
It supports automatic switching between 2.4G and 5.8G dual frequency bands, with automatic frequency hopping upon signal interference, delivering a maximum control and video transmission range of 20KM.
Signals remain steady during long-distance patrols or in harsh electromagnetic environments.
Compatible with low-latency HD cameras for ultra-real-time video feeds. The high-brightness display delivers clear visibility under direct outdoor sunlight. Real-time OSD overlay presents flight data and video transmission status at a glance.
3. 480g Lightweight, Effortless for Heavy-Duty Operations
Integrated with a 4.5-inch HD screen, the whole unit weighs merely 480g, featuring a compact, portable design. Its detachable joystick caps allow you to slip the remote straight into your tool bag for easy transport.
Despite its lightweight build, it houses a built-in 10,000mAh battery that delivers 5 to 6 hours of continuous operation, eliminating worries about charging during outdoor missions.
Ergonomically shaped hand grips fit naturally in palms. Equipped with 11 channels and precisely arranged buttons, it enables smooth blind operation and offers great handling during intensive work sessions.
Maximize Cost Performance & Boost Unmanned Operation Efficiency
The remote controller serves as the core control hub of the entire unmanned system. Skydroid’s newly launched G11 remote controller delivers professional-grade control experience at a 3-digit price tag. Balancing outstanding cost efficiency, it features 20km low-latency telemetry and image&video transmission + open-source Linux system. Compatible with various unmanned equipment including robots, helicopters, fixed-wing aircraft, multi-rotor drones, UGVs and USVs. Its exceptional cost performance frees industry practitioners from budget dilemmas when purchasing in bulk or rolling out projects.
