New PixHawk 6c Throttle issues
I’ve tried this post before but I don’t think I explained the symptoms clearly.
I have my Tarot 650 flying well with my original HB Pixhawk 6c. Throttle response was nice and progressive allowing for smooth liftoffs, hover and flight. Unfortunately this original 6c suddenly failed (!) losing the FMU side altogether!!
I order a replacement HB 6c and now have it installed in the same setup as the original. However for whatever reason the output from throttle inputs is frightening different and I’m really stuck trying to understand.
When I raise the throttle nothing much happens until about mid-throttle. At that point the motors all come alive but not high enough to takeoff (thank goodness). Moving the throttle still higher I suddenly reach essentially full throttle and if not tethered the quad would uncontrollably take off with no possibility to achieving anything like an altitude hold condition.
Since I’m using the exact same parameters as with the previous (original) 6c I’m truly at a loss.
If anyone could give a little guidance about what to do about this situation I’d be eternally grateful. As it is right now i”m absolutely stumped and dead in the water.
TOM
Post a link to a .bin flight log of the take-off attempt.
Looks like the classic “test a closed loop system in a open loop way and hope it does not notice it”.
That test is invalid and the results expected. But do post a .bin file.
Did you copy really all parameters from the old to the new FC? How you did this?
Some parameters, all calibration and some tuning parameters are HW dependent and need to be readjusted also if the module is in principle the same.
@mandoman You will be a lot better off using the AMC software to import the settings from the old FC into the new FC while guiding you though the process of calibrating the new FC parameters.
I did it by hand “one by one”!
Thanks for your reply!
I have experience (all BAD!!) with AMC. It simply has never done anything useful for me. It just produce a bunch of contradictory setting – a disastrous waste of time.
I’d really like to hear if you have anything to offer about the peculiar throttle response issue I’m seeing. Thanks
Tom
I’m sorry I’m just not smart enough to decode your response :-(..
Thanks anyway
TOM
Unless you share a log or, at a bare minimum, some saved parameters, we really can’t diagnose anything. It’s highly likely you flubbed the config, but that’s just speculating.
If you enter incorrect data it will produce contradictory settings.
And If you do not understand that some parameters require different values depending on the tuning step you are in, you might perceive that as contradictory settings, when in reality that is the correct way to do it.
Anyway, give concrete examples and I will help you understand, or fix the issue if there is one.
Post a .bin file or even better use the “Zip Vehicle for Forum help” button and post the resulting zip file
Not hard to decode posting a link to a .bin log file.
Here are some threads explaining it:
