I would like to request a feature for arducopter. I am running a pixhawk with 3.6 I would like the capability to make a command happen based on parachute deployment. So recently I had an auto deploy due to a bad esc or motor (not sure which, upgraded both to newer ) when the quad came down it landed on it’s bottom and destroyed my 200$ camera gimbal and partially hurt my GoPro. I was wondering if there is a way we could select an option to have the landing gear deploy based on auto chute deployment. This would I believe aid in the destruction of a gimbal and camera. Even if the landing gear is slightly damaged, it would still be cheaper for me to replace a 30$ set of landing gear than replace 400-500$ of gimbal and camera equipment. Until then, I have clipped my chute connection to the bottom of the quad as this will cause it to fall on it’s top but I’d still it rather fall correctly . Thank you in advance and thank you to all the hard working developers working on this project. The community really owes everything to all of you
I’m not sure what you mean, what is lua?
