@amilcarlucas I recently tried to walk through all the steps of the AMC in “simple” mode and got the following result. One thing that was strange to me was after I completed the quicktune flight, I came back and plugged in to AMC, etc then in step 23 it had autofilled the window with all the default PIDs instead of the ones that I had gotten from doing the quicktune. I continued on and it did in fact overwrite all my PIDs back to default before proceeding to the next step, so I had to use Mission Planner to restore the quicktune PIDs.
I’m sure I’m missing some things while using this tool, but maybe the .zip file will help you see what was going on along with your request for it from Discord. Thanks in advance for taking a look!
Also it seems like updating the software doesn’t work, atleast on Linux. So what I do is clone the repo, pull new changes and install from this local directory
Um, you can find that in Mission Planner. Normal UDP isn’t working for me probably because I’m using Dronebridge Clinet mode with mobile hotspot. But UDPCI works. I think the difference is that the Ground Station initiates the communication rather than the FC but don’t hold me to this.
