New ArduPilot methodic configurator GUI
v0.9.3
Latest
@github-actions github-actions released this 16 Aug 12:41
v0.9.3
881ca90
Commits
Many thanks to @lida2003 for helping out in testing this release
The latest development version supports automatic lua scripting uploading. You no longer need to:
  • download lua scripts from the internet
  • upload lua scripts to your flight controller
The software does all that for you.
v0.9.5 Latest
Commits
Hello.
I would like to ask about the step 5 of the Methodic Confgurator guide. It is mentioned the following:
Fom the existing templates, select the one most similar to your vehicle:
But in Linux I don’t have the \vehicle_template folder at all.
In MS Windows I have such folder but there is no template for SpeedyBee-F405-v3. What I can do in this case? Should I just use “Use paramteres values from connected FC, not from template files” and no other option I have?
If yes, after that I see the window with Vehicle Component editor. If I don’t have for example ESP32 WROOM for Telemetry or I don’t have GNSS Receiver then how to disable Telemetry or GNSS?
Thanks in advance
ArduPilot supports around 110 different flight controllers. Sorry, I can not and will not create templates for every single one. What you should do is to take a look at the existing templates and select the most similar to your vehicle and use that one.
No, that is for the case when your FC has already been correctly configured, and that is not the case.
If you do not have that delete the information on those fields.
with my SpeedyBee F405 V3, the props and other components are quite different from what I see in the templates. So, if I choose a template, almost everything will be changed anyway. I’d like to know what this information is needed for. Does it need to be very precise?
Thanks in advance for an answer.
What about ports? There is no option just to remove information.
It is used to set the values of parameters that depend on it. Yes it needs to be very precise.
Feed the tool with wrong/incomplete information and the parameters will be wrong.
The exact dependencies and their formulas are described in the “forced_parameters” and “derived_parameters” of the configuration_steps_ArduCopter.json file
Then leave them unchanged
In ESC part of Vehicle Component Editor there ESC part and in FC Connection is mentioned SERIAL5 but in my case ( SpeedyBee F405 V3 BLS 50A 30x30 FC&ESC Stack - Speedy Bee ) I am using stack and it seems to me that not SERIAL5 is used but a separate port for connection and it is not really clear what SERIAL is there. What should I do in this situation?
And what is the way to update the configutaion if I already pressed “create…”?
Thanks in advance
You should find which port is used and enter it.
What exactly do you mean with update?
What do you expect the software to do?
There is no specific port. The special connector is used to connect FC and ESC:
For example, for ESC I decided to keep what was in vehicle template. ( SERIAL5 ) but if I will need to update this value should I re-create template from the scratch?
Help/automate configuration of a drone.
Are you referring to ESC Telemetry? If yes, your ESC BLS 50A 4-in-1 ESC does not support that.
UART	6 sets(UART1, UART2, UART3, UART4(Dedicated for Bluetooth connection)), UART5(Dedicated for ESC telemetry),UART6
ESC Telemetry	UART R5(UART5)
ESC Telemetry	Not supported
BL32 50A 4-in-1 ESC supports ESC Telemetry.
I am speaking about SERIAL5 and Protocol inside ESC.
If you change something in the esc configuration on the component editor window then you need to select the esc.param in the parameter editor window combobox and validate the changes and press upload.
If you change a gnss configuration in the component editor you need to do the same on the gnss.param file.
So no need to start from scratch.
Thanks for clarification.
Could you please help me with “FC Connection” ( type and protocol) which is mentioned in ESC? I can’t find in the speedybee doc what is type and protocol used between FC and ESC… Even if look at available options in “Type” ( SERIAL{0-8}, CAN{1-2} ) then I am not sure what shoud be choosen… The same for “protocol” I don’t see any of mentioned options there in the doc of my ESC. The only word connected to protocol and my ESC Protocol is DSHOT300/600 but I guess it is something different from what should in “Protocol” in configurator as available options are {FETecOneWire, Torqeedo, CoDevESC}.
Choose
main out
Dshoht600
During configuration of 05_remote_controller.param I found the following:
Is it an issue if it is mentioned Matek H743? I don’t know from where Configurator took this information.
My vehicle_components.json doesn’t have such information:
“Format version”: 1,
“Components”: {
“Flight Controller”: {
“Product”: {
“Manufacturer”: “SpeedyBee”,
“Model”: “speedybeef4v3”,
“URL”: “SpeedyBee F405 V3 BLS 50A 30x30 FC&ESC Stack - Speedy Bee”,
“Version”: “V3”
“Firmware”: {
“Type”: “ArduCopter”,
“Version”: “4.4.4 official”
“Notes”: “”
“Frame”: {
“Product”: {
“Manufacturer”: “Mark4-7inch 295mm\n”,
“Model”: “Mark4”,
“URL”: “”,
“Version”: “”
“Specifications”: {
“TOW min Kg”: 0.6,
“TOW max Kg”: 0.6
“Notes”: “”
“RC Controller”: {
“Product”: {
“Manufacturer”: “TBS”,
“Model”: “tbs tango 2 pro”,
“URL”: “https://www.team-blacksheep.com/products/prod:tbs_tango2_pro”,
“Version”: " 2 pro"
“Firmware”: {
“Type”: “Tango 2 XF”,
“Version”: “6.17”
“Notes”: “”
“RC Transmitter”: {
“Product”: {
“Version”: " 2 pro"
“Firmware”: {
“Type”: “Crossfire TX”,
“Version”: “4.0.0”
“Notes”: “Built-in trasmitter”
“RC Receiver”: {
“Product”: {
“Model”: " TBS Crossfire Nano SE",
“URL”: “https://www.team-blacksheep.com/products/prod:crossfire_nano_se”,
“Version”: “?”
“Firmware”: {
“Type”: “Crossfire”,
“Version”: “7”
“FC Connection”: {
“Type”: “SERIAL6”,
“Protocol”: “CRSF”
“Notes”: “This receiver is on the vehicle and is connected to the flight controller”
“Telemetry”: {
“Product”: {
“Manufacturer”: “”,
“Model”: “”,
“URL”: “”,
“Version”: “”
“Firmware”: {
“Type”: “”,
“Version”: “”
“FC Connection”: {
“Type”: “SERIAL3”,
“Protocol”: “MAVLink1”
“Notes”: “”
“Battery Monitor”: {
“Product”: {
“Manufacturer”: “”,
“Model”: “”,
“URL”: “”,
“Version”: “”
“Firmware”: {
“Version”: “4.4.4”
“FC Connection”: {
“Type”: “None”,
“Protocol”: “Disabled”
“Notes”: “”
“Battery”: {
“Product”: {
“Manufacturer”: " Tattu ",
“Model”: “Tattu R-Line Version 3.0 1300mAh 22,2V 120C 6S1P XT60”,
“URL”: “Akumulator Tattu R-Line Version 3.0 1300mAh 22,2V 120C 6S1P XT60 - MegaDron.pl”,
“Version”: “”
“Specifications”: {
“Chemistry”: “Lipo”,
“Volt per cell max”: 4.2,
“Volt per cell low”: 3.6,
“Volt per cell crit”: 3.55,
“Number of cells”: 6,
“Capacity mAh”: 1300
“Notes”: “A normal battery”
“ESC”: {
“Product”: {
“Manufacturer”: "SpeedyBee “,
“Model”: “BLS 50A 30x30 4-in-1 ESC”,
“Version”: “1”
“Firmware”: {
“Type”: “BLHeli_S JH50”,
“Version”: “32.10”
“FC Connection”: {
“Type”: “Main Out”,
“Protocol”: “DShot600”
“Notes”: “Runs BDshot600”
“Motors”: {
“Product”: {
“Manufacturer”: " EMAX”,
“Model”: “EMAX ECOII Series ECO II 2807 6S 1300KV 5S 1500KV 4S 1700KV Brushless Motor”,
“URL”: “https://www.aliexpress.com/item/1005004905551761.html?spm=a2g0o.order_list.order_list_main.25.3c381802zQTaAO&gatewayAdapt=glo2pol”,
“Version”: “”
“Specifications”: {
“Poles”: 14
“Notes”: “”
“Propellers”: {
“Product”: {
“Manufacturer”: "Gemfan ",
“Model”: “Gemfan Flash 7040 7X4X3 3-Blade PC Propeller for RC FPV Freestyle 7inch Long Range LR7 Drones”,
“URL”: “https://www.aliexpress.com/item/33051616437.html?spm=a2g0o.order_list.order_list_main.35.3c381802zQTaAO&gatewayAdapt=glo2pol”,
“Version”: “”
“Specifications”: {
“Diameter_inches”: 7
“Notes”: “”
“GNSS Receiver”: {
“Product”: {
“Manufacturer”: “”,
“Model”: “”,
“URL”: “”,
“Version”: “”
“Firmware”: {
“Type”: “”,
“Version”: “”
“FC Connection”: {
“Type”: “CAN2”,
“Protocol”: “None”
“Notes”: “”
“Program version”: “0.9.5”,
“Configuration template”: “4.4.4-params”
Sometimes I see the following erros:
Screenshot 2024-09-08 153146
Where can I read what is the reason for such failure?
it is a sample template embedded during installation, users are supposed to understand what things are integrated and make edits to the sample template where the configurator brings it out from the more than 1000 parameters that are commonly needed to change according to your drone components setup to achieve successful flight minimize crashes. read more about it here.
It is under your work directory and has the filename example 05_remote_controller.param
Matek H743-specific: Hardware-Pin Rx6 is Rx from UART 7
BRD_ALT_CONFIG,1  # Matek H743-specific: Hardware-Pin Rx6 is Rx from UART 7
There is a high chance your SpeedyBee FCU does not support it. you have to read the FCU/ESC manual.
I do not think your ESC is supported.
Directly to the left of that parameter, there is a “Del” button press it and select yes.
