Exact same set up in cables and computer, but after 4.7.2 coincidentally I’m now getting write failures for every parameter where you press write parameter and it comes back failed, however, there are many times when you can go and check and see after a reboot that the parameter did actually write on some occasions so it’s not failing to write always. It’s just reporting a failure. Any suggestions. PIXHAWK6C and mission planner 1.3.83.
There’s no known issue like that with the firmware.
Try doing the Beta updates to MissionPlanner.
Unless you’ve got some special reason to stay with a specific version of MissionPlanner, then best to do the Beta updates anyway.
Also you can try the “Param gen” - press Control F and look for the param gen button about 1/4 of the way down the left column. Watch network activity from Task Manager to see when it’s finished.
Thanks I’ll try the beta.
