Negative temperature
I had a flight in the snow.
The thing i have noticed, is that when temperature goes below 0°C than i have strange readings.
How does APM sends negative temperature?
Here is the short video about it: (Top right corner)
http://www.youtube.com/watch?v=bqQpYdXpJB0&feature=youtu.be
Thx,
Gábor
Hi Gábor,
I think that is probably a bug in the OSD firmware. The temperature is sent as a signed 16 bit intteger in 100ths of a degree C. I suspect the OSD code is formatting it as a signed number.
Maybe contact the OSD firmware maintainers to confirm and get a fix?
Cheers, Tridge
[quote=“tridge”]Hi Gábor,
Cheers, Tridge[/quote]
Hi Andrew,
That would be me. :unamused:
You are absolutely right.
We had it as; static uint8_t
So it does not handles negative numbers.
I was sure about the variable, but it turned out that…
Sorry, my fault.
I will fix it.
Thx,
Gábor
Gabek, Where can I find out more about this OSD?
[quote=“gabek”]That would be me. :unamused:
[/quote]
ha, classic!
Thanks!
Hi Craig3DR,
Our project is here: https://code.google.com/p/minimosd-extra/
[quote=“tridge”][quote=“gabek”]That would be me. :unamused:
[/quote]
ha, classic!
Thanks![/quote]
Ohh well…
I think we have changed it when tried to reduce code size. (Without thinking…)
It is fixed now.
Just comitted.
Gábor
