needs example of python script to run drone using pix4flow with no gps
mport time
import math
import numpy as np
from dronekit import connect, VehicleMode, LocationGlobalRelative
Connect to the vehicle
connection_string = ‘/dev/ttyACM0’ # Replace with your connection string
vehicle = connect(connection_string, baud=921600, wait_ready=True)
Set vehicle mode to GUIDED and ARMED
vehicle.mode = VehicleMode(‘GUIDED’)
vehicle.armed = True
Wait until the vehicle is armed and in GUIDED mode
while not vehicle.mode.name == ‘GUIDED’ or not vehicle.armed:
time.sleep(1)
Take off to a height of 5 meters
target_altitude = 5
vehicle.simple_takeoff(target_altitude)
Wait until the vehicle reaches the target altitude
while True:
current_altitude = vehicle.rangefinder.distance
if current_altitude >= target_altitude * 0.95:
break
time.sleep(1)
Disable GPS and use Pix4Flow for position estimation
vehicle.parameters[‘EKF_GPS_TYPE’] = 3
vehicle.parameters[‘EK2_GPS_TYPE’] = 3
vehicle.parameters[‘EK2_FLOW_DELAYCOMP’] = 1
vehicle.parameters[‘EK2_FLOW_USE_HGT’] = 1
Wait for the Pix4Flow camera to start streaming data
while not vehicle.groundspeed:
time.sleep(0.1)
Set the maximum ground speed to 1 m/s
vehicle.parameters[‘WPNAV_SPEED’] = 100
Move forward for 5 seconds
start_time = time.time()
while time.time() - start_time < 5:
vehicle.send_mavlink(vehicle.message_factory.set_position_target_local_ned_encode(
time_boot_ms=int(time.time() * 1000),
target_system=vehicle._vehicle_id,
target_component=0,
coordinate_frame=8,
type_mask=4039,
vx=1,
vy=0,
vz=0,
yaw_rate=0,
time.sleep(0.1)
Turn right for 5 seconds
target_component=0,
coordinate_frame=8,
type_mask=4039,
vx=0,
vy=0,
vz=0,
yaw_rate=-math.pi/4,
time.sleep(0.1)
target_component=0,
coordinate_frame=8,
type_mask=4039,
vx=1,
vy=0,
vz=0,
yaw_rate=0,
time.sleep(0.1)
Turn left for 5 seconds
target_component=0,
coordinate_frame
