I got a quad fly well with Pixhawk4 Flight controller, but for some reason I need to change the FC to Cube Orange. Since then, the vibration went too wild and unstable, so I started the Harmonic Notch Tuning with the guide from Docs.
The quad did much better after some tuning, but there is still some unstable up and down movement once a while. And I don’t know what parameters to adjust now.
Quad Setup below
FC : Cube Orange
GPS : Here 3
Motor : MAD 5008 KV340
Props : 1760 Composite Fold
Weight : 4 kg
After hover learning, my MOT_THST_HOVER is 0.2, I tried to multiply the square root of (min_freq/hover_freq) like the guide says and turned INS_HNTCH_REF to 0.07. But the situation got a lot worse, so i changed it back.
Thanks for the reply!! Is there any else that I can try? Or just keep tuning up the INS_HNTCH_ATT?
I think it’s inadvisable to set an attenuation so high. I would set it back to standard values.
INS_HNTCH_ATT,40
INS_HNTCH_BW,24
INS_HNTCH_ENABLE,1
INS_HNTCH_FREQ,48
INS_HNTCH_HMNCS,3
INS_HNTCH_MODE,1
INS_HNTCH_REF,0.2
