I have a DJI F450 copter with a Pixhawk. I am using a FlySky FS-T6 transmitter and FS-R6B receiver. The receiver connects to the Pixhawk using a PPM Encoder.
The copter is working well in Stabilize mode, manually controlled by the transmitter.
However, I would like to fly an automated (GPS guided) flight, as I am interested in using this for mapping. I have learned how to create the flight path and load it into the copter. Yesterday, we took the copter outside, with a flight plan loaded, and attempted to fly it. But, we couldn’t get it to take off. It wouldn’t arm in Auto mode.
I watched a video which describes that it is a good, safe idea to have a dedicated toggle switch to quickly flip between Stabilize mode and Auto mode. I’m not sure that this is a necessity for making an Auto flight or not. To date, and during my testing yesterday, the flight modes have been controlled on Channel 5, using the VRA dial on the transmitter.
Also, it looks like Channel 6 might be available, but I’m not sure.
The FS-R6B receiver has 7 ports, the top most of which is labeled “BAT” and the remaining 6 ports are labeled channel 1 through channel 6. The BAT port is empty, and all six of the channel ports are used by the plugs coming from the PPM encoder, with wiring as follows:
Channel 1, single wire, signal, purple
Channel 2, single wire, signal, blue
Channel 3, single wire, signal, green
Channel 4, single wire, signal, yellow
Channel 5, single wire, signal, orange
Channel 6, three wires - signal, white; positive, red; negative, black
I note that the plug in the Channel 6 port has three wires - white, red and black, and that this is different than the remaining five plugs, which only have one wire each. Also, the outgoing plug from the PPM encoder, connected to the (left rear) RC port on the Pixhawk happens to also have white, red and black wires. Maybe this means that I don’t have a sixth channel available?
On the FS-T6 transmitter, under the functions menu, there is a screen that shows settings for auxiliary channels, specifically channels 5 and 6. Channel 5 is set to be controlled by the VRA dial (“Source VrA”). Channel 6 however, simply lists “Source Used”, and does not appear to be controllable. Does this confirm that Channel 6 in unavailable to me?
Finally, in Mission Planner, v. 1.3.45, at Initial Setup>Mandatory Hardware>Radio Calibration, Channels 1 through 4 operate as expected to control pitch, roll, throttle and yaw (not necessarily in that order). Channel 5 (set to VrA dial) is set up to switch between 6 different flight modes, as defined at Initial Setup> Mandatory Hardware>Flight Modes.
In exploring this some more, it appears that one way to work around this is to set Channel 5 to one of the toggle switches on the FS-T6 transmitter (for example, SWA). This appears to work. It would allow for quickly switching between Stabilize and Auto modes.
Suggestions for getting going with an auto flight are kindly appreciated.
Thanks,
Al
