Hi All,
I need help figuring out a yaw issue.
I just test flew a new build for the first time:
Orange Cube w/ ADS-B carrier board
U5 v2.0 T-Motors
16.5 T-Motor props
Here3 GPS
Air A40 ESC T-Motor
frame is custom (3D printed)
First flight was a simple takeoff, short hover, and return, all looked good.
The second flight was a 3 waypoint program with the 4th waypoint being RTL. The quad hit all waypoints at the designated altitude and landed fine, though it did so while yawing slowly in a right rotation.
The third flight was a takeoff to 10m then put into Autotune. Instead of the standard twitch dance of Autotune, the drone did a slowly expanding spiral in a clockwise rotation.
I kicked it into position hold and tested each input:
- Ascend and descend are perfect
- Right yaw seems fine, but full left yaw produces almost no response.
- Forward input causes the drone to move forward while curling to the right.
- I can’t accurately describe what back stick does as by this time I was frustrated and just landed.
I downloaded the data flash logs and they can be found HERE
Any help will be very appreciated! Thanks for reading this and stay healthy out there!
Cheers,
Pete
