Hi!
I’m trying to set up CAN parameters for NRA24 radar, but the download fails at approximately 25%, no matter how I try to download it(
Maybe someone can share already downloaded software?
Hi!
Do you mean the settings on the NRA24? I’ve never been able to get the NSM Tools from Nanoradar’s website to work, but if you ask their tech support, they can send NSM Tools that do work. If you are using only one NRA24, though, you shouldn’t need to change anything (you can’t share the Nanoradar bus with other mfg CAN devices).
Now we update our web, you can find our software as the link below:Tool Download_Hunan Nanoradar Science &Technology_Accurate Detection
Dear,
Did you resolved the issue?
The CAN communication worked and the range sensing also?
Regards
HI!
Yes, I was able to reach support via email.
Dear, did you need to change the firmware of NRA24 to be compatible with ardupilot? Or you only downloaded the software?
Kindly provide more details.
Regards
I was looking for software for NRA24, and support helped me. Now I have issues making it work on the same bus with the AP_Peripheral DroneCAN device.
Hello there,
I believe you cannot get other DroneCAN devices working on the same bus as the NanoRadar, because the NanoRadar uses a different CAN protocol, RadarCAN if I´m not mistaken.
When you change the CAN_D1_PROTOCOL from 1: DroneCAN to 14: RadarCAN
Hope this can help you .
I´m currently struggling to get a NanoRadar24 to work, I can´t get any kind of data, not with a TTL adapter, so I now think that I got a CAN version for some reason. The issue is that I can use a CAN debugger because of the RadarCAN protocol, and cannot get any reading on the Cube.
Hi!
DroneCAN now supports two different protocols on the same bus, so you can support it with the same speed and on the same bus.
Also, Nanoradar can send you a firmware for NRA24 with native DroneCAN support.
