Nanoradar MR72 ignore parameters
Hello to all
I am using NanoRadar MR72 as a proximity sensor.
The sensor is mounted on the front of the drone and it can see 120 degrees facing itself.
I want to use ignore parameters to detect only 45 degrees forward.
I set the parameters as follows:
PRX_TYPE, 3 (TeraRengerTower)
PRX_IGN_ANG1, 45
PRX_IGN_ANG2, 90
PRX_IGN_ANG3, 315
PRX_IGN_ANG4, 270
PRX_IGN_ANG5, 0
PRX_IGN_ANG6, 0
PRX_IGN_WID1, 45
PRX_IGN_WID2, 45
PRX_IGN_WID3, 45
PRX_IGN_WID4, 45
PRX_IGN_WID5, 0
PRX_IGN_WID6, 0
But it did not work. And I do not see any difference in the performance of the sensor.
Capture
Any suggestions and solutions to solve this problem are welcome. Thank you
@samane.s.h
Have you solved the issue?
Can you please provide nanoradar mr72-ardupilot documentation (wire schematics and parameters)
