Hello there!
As a group of 5, we have been building a quadcopter for our school project. Even though our quadcopter stays fairly stable for around 5-6 seconds flying, it rolls and crashes right after that.
We are using a SpeedyBee F405 Wing APP and a JawsPawer 5000mah 3S LiPo battery. The logs show that voltage is sagging too much. Our battery claims that it is 100C but we don’t trust it as we got it from a really cheap store. We’ll try again with a Turnigy 2200mah 35-45C LiPo battery after I write this and I’ll add more to this post with those results after that flight.
If anyone could give a second look at the logs that would be greatly appreciated.
FYI: Motors: RS2205 RaceStar *4, esc: skywalker 30A *4. 7 inch props.
If the copter tries to flip over immediately when throttling up, then it’s motor order.
Use the MissionPlanner motor test extensively.
Use the RC Calibration screen check your RC pitch channel is working the correct way around, it’s opposite to what is usually expected.
In our recent tests drone is lifting up to 2 meters but any higher the drone becomes unstable and either falls or does a battery failsafe and lands. I believe as you said our drone is probably overweight for these small motors. We will consider redesigning the frame.
