while I was flying my drone its suddenly crashed badly in the air, the auto analyze outputed the follwoing
Log File C:\Users\user\AppData\Local\Temp\tmpAA1F.tmp.log
Size (kb) 5516.919921875
No of lines 58998
Duration 0:02:59
Vehicletype ArduCopter
Firmware Version V4.5.4
Firmware Hash fd1bcc61
Hardware Type
Free Mem 0
Skipped Lines 0
Test: Brownout = GOOD -
Test: Compass = FAIL - Large change in mag_field (55.15%)
Max mag field length (572.00) > recommended (550.00)
Test: Dupe Log Data = GOOD -
Test: Empty = GOOD -
Test: Event/Failsafe = GOOD -
Test: GPS = GOOD -
Test: IMU Mismatch = NA -
Test: Motor Balance = UNKNOWN - ‘QUAD/X’
Test: NaNs = FAIL - Found NaN in BAT.Curr
Found NaN in BAT.CurrTot
Found NaN in BAT.EnrgTot
Found NaN in CTUN.DSAlt
Test: OpticalFlow = FAIL - ‘FLOW_FXSCALER’ not found
Test: Parameters = FAIL - ‘MAG_ENABLE’ not found
Test: PM = UNKNOWN - ‘NLoop’
Test: Pitch/Roll = UNKNOWN - ‘BarAlt’
Test: Thrust = GOOD -
Test: VCC = UNKNOWN - No CURR log data
its seems that the problem was with the compass is that possible since i was flying the drone in stablize mode. I will apperiate any help and bossible solution now my pixhawk power port is not working.
We need to see a .bin log file to tell anything. A compass generally doesnt cause a crash, in fact the compass can disappear or go bad and the EKF can handle it and should just go into Land mode if required.
The copter doesnt really get flying well in this log. I’m assuming this is like a first flight??
Set ARMING_CHECK,1 and use MissionPlanner motor test to check all motors spin in the correct order and direction.
Then I strongly recommend you follow the new Configurator routine before attempting flight again.
no the copter was in the takeoff phase maybe the problem is from the RC, before that flight i was attempting to arm the drone but it did not successed the prearm error was RC2 is not natural i have change rc2_trim to 1510, one another possible reason could be one of motors stoped working as it is not receiving the pwm input from flight controller but I am not sure.
I’m a bit worried about the BEC supplying the flight controller with +5volts.
When the battery load increases with motor output (and the loss of control) the BEC voltage also drops down quite lot, so it’s not a very good regulator.
You might want to try adding a Low ESR capacitor to the input of the BEC, and also an ordinary electrolytic to the output, or just get a different power brick - there’s lots of good choices these days.
Thank you all for your help. now the pixhwak power1 port is not working but when i power the pixhwak through the usb port its working fine is it a good idea to power the pixhwak thoruhg the usb port instead of the power1 I know there will be no feedback for the battery voltage but is there any other issues?
and how i could test if my compass is working well?
If it’s wire connection or propeller mounting skew issue, RC out will go high.
I think it might have significant aerodynamic issue at that moment. As it fly not high enough(3meters, motor3/4 did come back power right after idle) , but it does not have time to recover from unstable state.
— EDIT:
Please don’t spin/yaw that much when you are NOT confident with you tuning parameters.
