Multi-drone communication setup using RFD900x radios (unlocked)
Dear RFD Support Team,
I hope you are doing well.
I am currently working on a multi-drone communication setup using RFD900x radios and would appreciate your guidance on a few technical aspects.
System Overview:
  • Ground Control Station (GCS) connected via RFD900x
  • Multiple drones (currently 4) each equipped with RFD900x modules
  • Using ArduPilot with MAVLink communication
  • Goal: Enable reliable multipoint communication and coordinated control (swarm-like behavior)
Challenges I am facing:
  1. Difficulty in configuring reliable multipoint communication between one GCS and multiple drones.
  2. Understanding how MAVLink messages are handled in a multipoint RFD setup (broadcast vs targeted messages).
  3. Occasional packet loss / instability when multiple nodes are active.
  4. Clarification on optimal firmware settings for mesh or multipoint configuration (e.g., NetID, Node ID, air data rate, ECC, etc.).
Specific Questions:
  • What is the recommended configuration for a multipoint setup with one GCS and multiple air units?
  • Is there an official or recommended approach for swarm communication using RFD900x?
  • How does the radio handle simultaneous MAVLink streams from multiple vehicles?
  • Are there best practices to reduce congestion and ensure stable links in such setups?
  • Would you recommend using a gateway node or any specific topology?
If needed, I can provide logs, configuration files, or setup details for better analysis.
I would greatly appreciate any documentation, examples, or guidance you can share.
Thank you for your support.
Email support@rfdesign.com.au
Have you been through the docs?
Yes, I have gone through documentation and tested RFD900x Multi-point firmware, and the uav connection is not made even after following the example settings.
I tried this a couple of years ago and kept running into walls. Decided the RFD firmware was not complete.
In the end I equipped the drones with ESP8266 modules and used a gaming wifi router/access point with a Rpi to handle the traffic.
Successful swarm of 8 drones - signal was ok within the limit of VLOS flight. (500m horiz, 120m height)
