Having trouble using client mode? I’ll save you all ~18+ hours of messing with hostapd/wireshark/iptables trying to figure out what’s going on:
No sure what you or that FCC correspondance means?
Client mode works just fine. Or are you referring specifically to 802.11n (as opposed to 11b/g)?
Yes, that’s what I’m referring to.
The difference in range ,is too small to mean anything if your referring to client to device. The increase in throughput would’t really benefit much. “N” also has a much higher power consumption.
