MP very slow with MicoAir H743 V2
Does anyone face the issue where Mission Planner gets the full parameters very slowly with MicoAir H743 V2 through the USB Type-C connector @115200bps? It takes approximately 2m30sec.
5/3/2026 1:34:14 pm : Frame: QUAD/X
5/3/2026 1:34:14 pm : RCOut: DS300:1-4 PWM:5-11
5/3/2026 1:34:14 pm : MicoAir743v2 00400022 32335116 37363536
5/3/2026 1:34:14 pm : ChibiOS: 88b84600
5/3/2026 1:34:14 pm : ArduCopter V4.6.2 (1ebd4d99)
SERIAL0_BAUD,115
SERIAL0_PROTOCOL,2
Mission planner 1.3.83 on Windows 10 pro
I still do not know what causes it to become slow suddenly.
I used STM32CubeProgrammer to flash version 4.6.3, reconfigure the parameters, and I’m back to normal MP connection speed now.
I think this page caused the problem. I encountered it again. After I changed one of the port values, the next USB connection continues to loop for parameter values.
Wonder if this user is experiencing the same issue.
Glad to see it solved for you. I’m using the V2 though in the AIO form factor. Occasionally, and by that I mean like 1 time out of 100, I experience a very slow param download, and there is no rhyme or reason. When that happens I usually unplug and try again and it works.
