In 4.6.2 firmware update the bcn_enable is not showing how to fix it.
For which flight controller? F4 based? Use custom.ardupilot.org
do you mean SCR_ENABLE?
i vtol we are using a x7+ and in a beacon we are using a v5 but both are in a same firmware 4.6.2
no no i am asking about beacon enable
This is the first time I’ve heard about “Beacon Enable.”
What I did is:
1 Connect two vehicles to one Mission Planner.
2 Set the parameters according to the Ship Landing documentation.
3 Right-click on the vehicle display and select “Forward between links” to exchange information between the vehicles. Message is appeared " Have beacon"
thank you for your respone , i will try it and see what is happing
Hello, have you resolved this issue? I’m currently encountering the same error. From the documentation, I understand that I should use MAVProxy to relay data and enter the `set fwdpos true` command, but I haven’t had success with this.
Currently, I’m able to connect two devices (a rover and a plane) using three P900 radios, but I **cannot confirm if the `GLOBAL_POSITION_INT` packets from the beacon are being forwarded to the aircraft**.
I **do not have a GPS device connected** at the moment, and I’m wondering if this is the cause of the problem.
Could you please help me with this?
