Mounting tape recommendations?
My Pixhawk and GPS both came with a gray 3M VHB foam mounting pad. It seems to work okay, but I need more of it.
There’s no product number on the pad - just 3M VHB. Does anybody know which model number it might be? The foam is gray, about 1.5-1.8mm thick, with a yellow paper backing.
I’m also open to other adhesive mounting recommendations; preferably something on Amazon.
That’s the name - 3M VHB. Search that on online stores.
Edit:
For some reason the link shows the 1/4 tape. I had intended to link to the 1/2” tape. Make sure to look around for the best price. If you purchase two rolls, the link provided by @Yuri_Rage (below) shows a better deal.
Original Post:
I think this is the stuff I use.
I’ve used the stuff with black foam. I generally use small pieces on things I want to take apart again.
VHB is a wide product line, and most of them aren’t foamy. Trying to find one with good vibration isolation.
This is the specific 3M VHB that I use.
I prefer this one meant for outdoor/automotive use. It’s not very foamy, and that’s part of why I prefer it. You generally don’t need a mechanical damping solution (despite what you might read in old documentation), and often times, it can be counterproductive.
