I have been experiencing some strange behaviour on my copter when I connect the battery.
It happens once in a while, that when I power on the copter the motors start spinning with random changes in rpm. I ignored it the first 2 times, and a power cycle fixed the issue but yesterday I nearly damaged my hand due to this issue.
Note: I feel like the issue may have something to do with the anti-spark connectors on the batteries. Maybe a slow connection process of the batteries cause a gradual increase is supply voltage to the system, that somehow initiates signal to the Tmotor integrated propulsion motor/esc config?
I’m not an electrical engineer, so if anyone has experienced anything similar or could give some input that would be great!
two pilots
two remote controller
two quard
the same passcode for receiver
within the short range of RC signal range
Now they got something dramatic happened. They powered their drone, and first guy thought it’s OK got connect the drone, arm and lift off the drone with acro mode. Actually he connect the another guy’s drone.
I have eliminated the possibility of it being interference from the RC signal. It seems to be something happening in the booting process of the ESC/Cube/system
Hi @MarcusL
Cubes or even Ardupilot generally dont have that issue, although there could be some parameters causing it.
Please supply your full parameter list as a file you can attach here.
Or a .bin log file created by setting LOG_DISARMED = 1
If you provide your full parameter list we may be able to tell what’s wrong, there are some misconfigurations that can cause ESCs to spin motors at inappropriate times.
The methodic configurator takes away the common causes of that and many other issues if followed correctly.
