[quote=“guy9495”]Hi MarkM and everyone else who helped
the issue is resolved with motor responded only with throttle. I learned in series of posts and did the following:
Here is what I did:
1-turned transmitter ON
2- Put throttle to max
3- connect the battery to quad
4- After hearing 1 or two beeps, disconnect the battery
5- Reconnect the battery
6- After hearing a short beep bring the throttle back to minimum and hear long beeps. At this point if you move throttle up, motors will spin
[color=#FF0000]7- Disconnect the battery and wait for 2-3 seconds and connect.[/color]
Done. Now motors will respond with any sticks and this is called[color=#FF0000] ARMED[/color].
thank you MarkM, Gordon and Mr. Internet.[/quote]
Guy:
I’m still on my first APM and I can understand your frustration. You seem to be a bit crossed up on what you are calibrating and why. This is what I’ve learned so far:-
(1) The APM assumes that the center of the sticks are at 1500ms. Therefore before you start anything you should reset the model memory (on your TX) so that all of the trims are in the centre and there are no mixes or servo offsets stored in the TX. (Easiest way to do this is start with a new model memory so that you know that everything is set to the factory defaults).
(2) Calibrate the ESCs (You only have to do this once):-
1- Turn transmitter ON
4- After hearing one (or two) short beeps bring the throttle back to minimum and hear long beeps. The ESC’s are now calibrated and will work normally.
YOU SHOULD NOT HAVE TO DO THIS AGAIN (Unless you change an ESC).
(3) Use the setup wizard in the mission planner to calibrate the sensors on your APM board and also teach the APM where your transmitter stick end points are (TX calibration). Make sure that you set up the AUX channels so that you can change APM modes on switch positions that you will remember!
Once you have done all of this the ESC’s will work properly, the APM sensors will work properly and the APM will understand what your TX sticks and switches are telling it.
Power Up sequence:-
2- Put throttle to [color=#FF0000]MIN[/color]
3- connect the battery to your quad
4- You should hear long beeps (ESC’s are now armed but the APM is not).
Arming:-
1- Place the quad on the ground on a level surface with a clear view of the sky.
2- Wait for the GPS to get a lock (and check that your telemetry is working Ok).
3- MIN Throttle and hold MAX right rudder. It should arm the APM after a few seconds.
Disarming:
MIN Throttle and MAX left rudder should disarm the APM.
No one said these things were simple.
Don’t give up, you just need to understand what order to do things in and why.
hopefully my notes might clarify the setup process for you a bit.
