I’m having a strange thing happen. I did a flight and found the performance not that great. Landed due to the battery running low. Changed to a new pack, then found the motors running really rough at idle and the motors not wanting to spin up. Sounded like rusted nails in a tin can.
My system did report software updates and I upgraded both Mission Planner as well as Copter to the latest versions.
The same issue persisted so recalibrated everything including the ESCs. Problem persists.
If I rotate the motors by hand then there are no obstructions.
if I test the motors one at a time motor 1 runs ruff consistently. Motors 2,3,4 runs smoothly every time.
Arming the system and getting initial idle speed, all the motors run rough.
MOT_SPIN_MIN is lower than MOT_SPIN ARM. You don’t want that. You have a reason for MOT_THST_EXPO at 0.2? Is this log with no props I suppose? It would be more useful to see the log from it flying.
Thanks for the response. Not sure where the MOT_SPIN_MIN and MOT_SPIN ARM values came from. I reset them to their defaults (0.15 and 0.10 respectively.
The motors do not spin up fast enough to get the drone in the air, even at 100% forward stick.
I did another motor test with motors 2, 3 and 4 running smooth but 1 sounds like its timing is out.
Thanks Alisteri set the values as they should be and still had strange behaviour
I defaulted the FC and reran the entire setup process, fligt settings, radio calibration, esc calibration, etc. The immediate motor test had all four motors run smoothley and i took the drone for a flight. All seemed fine in stabalise mode, tried alt hold and position hold. In position hold the drone drifted a bit and the controlls become progressivley worce.
I reset the the FC and set to stabalise. Spun the motors up a little and they sounded like a car misfiring, smooth cough, cough, smooth. I could not take off in this state.
Ive uploaded two log files. One testing stabalise, alt and position hold, the other of the irratic motor behaviour.
OK, it seems my issues are far from over. Since my last post the motors ran fine. This changed this afternoon though.
I flew with one battery without any issues.
Then changed the battery pack. No settings were changed between the two flights.
After arming the system the motors run rough and then settles after a few seconds. After a disarm and arm all seems fine (somewhat) until I take-off, the drone loses power and dropped to the ground.
During the next test flight, the drone seems better but then does a ground-loop, all on its own.
I’ve uploaded the bin file of the flight with the second battery pack as well as two short videos from the onboard GoPro. You can hear the motors running rough and settle to smooth.
My Advice: Follow the tuning wiki and do some alt hold tests. I think tuning them position controllers will resolve the issue about drone not being stable and oscillating when hovering.
I would say that your battery is sagging but you said you changed battery. BTW we also had that problem motors were turning like they have something in them we overcame that problem when we discovered that our motor cables were not soldered well to the 4in1 esc also we used a hair dryer to blow some air into the motors and it was resolved. We also had that issue but probably we had something in our motors but it is worth giving a shot
Thanks, I’ll have a look at the motors but don’t think there is anything in them. It is time for a bit of a cleanup. The cables from the ES to the motors are soldered properly without any dry joints. I’ll disassemble the drone and check the cables between the FC and ESC. There might be some issues there as this is the only link I cannot check without taking the drone apart.
Also this an other way we tried if you soldered it well. Run a motor test without propellers on Mission Planner just start with %15 throttle for 2 secs and start increasing slowly with %10 untill it removes the sound. Actually it works we also tried this and it works. But I dont know if it will damage the motors or smth. so it is experimental
Thanks. Yes, I’ve done that before. running on the bench it either runs well or runs rough. increasing the spin % while running rough does not change anything. While running roughly the motors will typically only spin up to around 10-15% power and nothing beyond that.
I’ll have proper look. The motors running rough is really starting to sound like a physical connection issue rather than a programming fault.
