Need some newbie help. I have built a F450 quad using an APM 2.6 board.
I am using a Flysky FSi6 transmitter to control this.
When I attempt to start the engines up, they run for a few seconds then all quit.
Any ideas?
Thanks
Any ideas?
Thanks
Since the motors started you should have a flight log of what it did. Hook it up to USB and download the log so we can see why it shut them down.
Mike
Ok, I got the motors running now, but everytime I unplug the lipo I have to go thru the entire sequence of plugging, unplugging, plugging unplugging etc to get them to respond again to throttle inputs. Can’t seem to find a simple arming sequence.
any ideas?
Thanks
Are you letting them idle? If you let them idle too long without applying any throttle, they will disarm. I think the time is 15 seconds.
http://ardupilot.org/copter/docs/arming_the_motors.html#id2
See the second note…
Like I said motors are running fine now. All throttle positions and not quitting. Thing is I do
not know how to rearm the motors so they run after disconnecting the battery.
When I do I have to go thru an entire sequence, long sequence of plug, unplug, plug unplug
or they won’t run again. There must be something I’m missing.
Thanks
