I’m new with drone
Hi
Based on the setup and the attached pictures, everything seems to be connected correctly. However, when I move the throttle on my transmitter, the motors do not respond at all.
I have verified the following:
• The transmitter inputs are detected correctly in Mission Planner → Radio Calibration.
• The Servo Output values appear normal in Mission Planner.
• The ESCs and motors function properly when tested separately with a PWM tester.
• The system is armed and there are no PreArm errors preventing operation.
Despite these checks, the motors still do not spin when I increase the throttle. Could you please help troubleshoot this issue?
Thanks in advance for your support.
