All,
Quad is an IRIS+, running latest version. The RCOU values for motors 1 and 2 are
essentially superimposed, and above them are motors 3&4, also superimposed.
I recall that all four should be superimposed…any suggestions welcome!
The attached .bin RCOU reflects the above. This .bin also reflects notch filters being
analyzed…should be don’t care.
I recently changed motor #1 with an exact replacement IRIS NOS motor.
THANK YOU!
Thanks! I was giving some thought to taking it apart (again!) and replacing the new motor on #1 with the original. The #1 arm was replaced; it came with motor installed.
Will check for any twist in the new one. Your response is appreciated.
