Motor selection for 5.2kg QuadPlane VTOL (4+1 Configuration) - 6S Setup*
Hello everyone,
I need some guidance on selecting motors for my QuadPlane VTOL.
Specifications:
- All Up Weight (AUW): 5.2 kg
- Configuration: 4 lifting motors for VTOL + 1 forward cruise motor
- Battery: 6S
I have previous experience with multirotors, where we follow a 2:1 thrust-to-weight ratio for motor selection.
My questions for a QuadPlane are:
1. For a QuadPlane, what thrust-to-weight ratio should we consider for the 4 VTOL motors? Is the 2:1 rule still applicable, or is it different?
2. What parameters should I consider for selecting the front cruise motor & lifting motors (power, thrust, KV, etc.)?
3. What are the best methods/calculations to select the optimal motors for this 5.2kg AUW - and I am using 6s battery
Any suggestions on motor KV, prop size, and thrust ratings…
Get a subscription to ecalc.ch. There’s a lot of variables for you to play with and that tool will get you on the right track. You might have to run it as two different drones. One quad, and one plane, but you should be able to get a reasonable idea of what you need.
Strongly recommend 3115 - 1050 motors. There is a bunch of them out there, T-motor, Xrotor from Hobbyking, especially the latter worked well and is dirt cheap (20 USD/piece).
What you want is a relatively high KV motor so that the prop is not excressivley big, because a big prop with low kv is efficient for hover, but is drag for forward flight.
2:1 is really the minimum thrust I would use. The quad plane uses much more poweer when it is tilted, i.e. when you have to go against the wind, the power requirement can increase considerably more than for a normal copter. Especially if you plan to use loiter in wind.
