Hello everyone
Why it is happening, that’s whenever I connect my battery,my motor starts running on the own , without any inputs given from transmitter
Cube orange plus
4.6.2
Mk 32 transmitter
Vector technics motor
Here 3+ gps
Hello @Anant_Mishra welcome to the community.
There is not enough information to provide an answer for that question. Without a .bin log file we can only speculate that your wiring and/or your configuration is incorrect.
Ok ,i will share the log tomorrow
Hey ,the incident happened on 1 nov ,and there are no logs generated
Set LOG_DISARMED = 1 so logging starts right at boot (even while disarmed). After your tests, please set it back to 0 to avoid large logs.
Also, what ESC are you using, and how is it connected to the FC — PWM, DShot (e.g., DSHOT300/600), or CAN (e.g., DroneCAN/KDECAN)? This affects the troubleshooting.
