I was using a DX7 to control my Hex with Pixhawk controller and my motor would spin when armed using (MOT_SPIN_ARMED) set to 70. I just purchased a DX8 and the motor do not spin when armed. With Throttle the motors spin, but not with low stick. (THR_MIN) is set to 130 and I have raised (MOT_SPIN_ARMED) as high as 120 with no spin when armed. I liked the (spin on arm feature) to let me now that the HEX is armed. I am using APM 3.2 thanks Larry
When my motors did not spin it was because I didn’t recalibrate the ESC’s. The new radio probably has a different PWM range.
To spin the motors they are at about 1100 PWM so if you can send in a log with logging turned up we can see what the RCOUT is and make some adjustments.
Mike
Thanks Mike I recalabrated the ESC and that solved thew problem Larry
