I think it should be possible to get the vehicle flying OK without FFT. Maybe provide an onboard log of the vehicle flying and we can give some tuning advice…
more info,stm32f427vit6 with 2MB flash,which support in-flight FFT.
OK, if the autopilot actually has 2MB then you should be able to load the regular Pixhawk firmware onto it (look for arducopter.apj in the linked folder). Please note though that the boards with the 1MB limit reported that they have 2MB of flash but actually only 1MB was usable. This was a hardware problem with the STM chip used.
emmm,maybe support documents need to fix and explain more than X mb
copter was test fly indoor,here is the file linkhttps://pan.baidu.com/s/1rIz3Y8b27GXcsAXmkNReWQ,the extract code is edwp.
I tried this a few minutes ago,FFT_ENABLE param appeared!with firmware
v4.1.0-dev
Re FFT_ENABLE appearing, this must mean that you installed the Pixhawk1 firmware (not the Pixhawk1-1MB firmware).
Sorry to be pedantic but just to be clear, the difference is not related to the firmware version number (e.g. Copter-4.0-beta4 vs Copter-4.1.0-DEV) it is related to which of the Pixhawk1 firmwares was used (e.g. “Pixhawk1” vs Pixhawk1-1MB).
In any case, glad that you’ve got the FFT feature!
After a while fly and download log,I further found that there is no data in value graph check in Bwavg,but with data check in Pkavg in the latest version of MP.
@andyp1per, can you help with this?
I’ve actually never used the FFT feature but please make sure to read the relevant wiki pages. You’ve probably already done this but just to be sure.
Please post your parameters and a log
Sorry I don’t read chinese
Hi Randy
One question: is it better to use the Firmware „Pixhawk-1M“ or the firmware „fmuv2“ for a 3DR Pixhawk. What is the difference between them?
BR
Harald
I think something like flight control unit seems different,mainly about microcontrollers etc.
It is generally better to use the more specifically named firmware (e.g. “Pixhawk1-1MB” rather than the more generic “fmuv2”) because there are cases where we can skip drivers or features not required for the board but I’m not aware of any actual difference between these two firmwares.
Pixhawk1 includes fmuv3. For those 2.4.8 boards I think this is what you want. At least it’s what I used when I had them flying. Ditched them all for F/H7 boards.
I agree with you and highly recommand firmware backup team to notice this
Looks like that’s the log file rather than the .bin file. Please can you send the .bin file - also send a dump of your parameters
I downloaded the files from flash.here is the list of relevant files,but which one is you need?
1980-1-1 XXX.log?[1 1980-1-1 星期二 上午 8-00-00.log.zip|attachment] (upload://m7H22GHeZezSz7vvLb7iShEVM0G.zip) (8.9 KB)
