MOT_PWM_TYPE and hobbywing xrotor 40A
Hi All
What value should be set in MOT_PWM_TYPE for Hobbywing Xrotor 40A ESC???
0 for Normal , 1 for OneShot, 2 for OneShot125 or something else ?
Regards
Hi, did you get an answer on this? I just built a new x500 kind of drone, installed the xrotor 40A and experiencing a strange behavior, arm goes well, motors rotate. after that, increasing throttle raises RPM just a bit and seems like limited, can not get a takeoff rpm.
Any idea?
did you figure that out?
Yes. Solved.
In the Blheli32 suite you must switch “low RPM power protect” off.
@Michael_Oborne MOT_PWM_TYPE parameter is not available in fixed wing.
I searched under full parameter tree nothing comes up.
