Monitoring multiple UAVs in qgroundControl
I want to monitor multiple UAVs on QGroundControl. I am using dronekit-sitl and its python api.
Using dronekit-sit two copter were simulated at port 5760 and 5780.
Using MavProxy I connected to both the copter and forwarded output on two ports
1.mavproxy.py --master tcp:127.0.0.1:5760 --out udp:127.0.0.1:14555 --out udp:127.0.0.1:14550
2.mavproxy.py --master tcp:127.0.0.1:5780 --out udp:127.0.0.1:14551 --out udp:127.0.0.1:14550
On QGroundControl I am not ablesee both copters. SOmeone please help me
From mavproxy, type “output” to check whether the outputs are there.
Also make sure each vehicle has a unique MAV_SYS_ID.
$mavproxy.py --master tcp:127.0.0.1:5760 --out udp:127.0.0.1:14551 --out udp:127.0.0.1:14550 --source-system 6
I am using --source-system option for assigning id.
This is output : STABILIZE> 2 outputs
0: 127.0.0.1:14551
1: 127.0.0.1:14550
You have two instances of sitl though. So the two sys id’s must be different. You’ve only listed for one of them.
Regards,
James
@james_pattison : parameter MAV_SYS_ID is not availabe in mavlink/mavproxy.
RTL> param set MAV_SYS_ID 2
RTL> Unable to find parameter ‘MAV_SYS_ID’
‘SYSID_THISMAV’ parameter for both UAVs are different
Regards ,
Dhananjay
