Monitor second Battery and receiving rotor RPM
First issue: Can anyone tell me how to add a second battery Monitor for the main 12s battery pack with the current drawing? I tried to use (battery moniter2) option but I was only able to choose the first slide down options, put it on ESC. But the rest are grey and not working.
Second Issue: how to get the rotor RPM? I see some people using small magnets and sensors connected to the Telemetry?
I have 200A HW platinum 4V opto, with Telemetry out single cable (P) that should go to Telemetry?
the issue here if the above statement correct; I use both telemetry ports Tel1 for CRSF receiver and tel2 for Mavlink,
I see there are also CAN1 & 2, can I connect the ESC telemetry single cable to one of them?
These are very important settings for big Helicopters…
Thank you
Ozzy
Parameters As350 Jan12-2013.param (18.8 KB)
